Results 1 to 7 of 7
- 11-06-2012, 06:11 PM
Thread Author #1
No 4G/3G/1X connection. help?
So, for the past couple months I have had problems with my phone dropping signal like 3G/4G then coming back after a minute or so then to either drop again or stay for the rest of the day. So today I turn on my phone and I have 0 data connectivity, no 4G,3G, or 1X. I can still receive texts (kinda it wants to give me message send or receive failures sometimes), I have tried everything I can think of battery pull, SIM pull (first time I did this I got 1x, then after a minute or so it went away), SD card pull. Multiple reboots, restoring to previously backed up points, trying other ROMs with no luck. Right now I am in the process of un-rooting my phone back to stock to see if anything helps, if not I plan on calling or going to the Verizon store tomorrow and seeing about a new SIM card. If that fails, I think i have insurance for a replacement and maybe I can push to get whole different phone (Galaxy S3 maybe, I doubt it). I also tried the ##778 and changing that setting. Unless I am completely missing something I think my phone is dead.
- 11-06-2012, 06:22 PM
Thread Author #2
- 11-07-2012, 05:52 PM #3
Re: No 4G/3G/1X connection. help?
thats weird, when you did the sim pull. did you start the phone and let it sit for aminute, then turn it off and reinsert the sim card? I know on my rezound I was only getting 3g, and Mr. Smith told me to do that and it brought my 4g back.
- 11-07-2012, 06:45 PM
Thread Author #4
Yeah I pulled the SIM and SD powered the phone on for about a minute or so, put SIM and SD back in and still had nothing. Still working good on stock for now, I will probably root again later when I feel like messing with it. When my headphones are plugged in my ringtone still goes through the speaker on the phone, which I didn't realize until my phone went off in school today with headphones plugged in. It has never done that before.
- 11-07-2012, 06:46 PM #5
I have had the same problem for the past 2 months. Did a factory reset on October 4th. Got better, but back to doing it again. I was happy when Verizon said they were sending me a new phone! Unfortunately, it's another Thunderbolt... I told the gal this is the last one I'm willing to try. Hopefully it lasts until my upgrade in April.
Sent from my ADR6400L using Android Central Forums - 11-08-2012, 07:24 AM
Thread Author #6
- 11-09-2012, 10:37 AM #7
Having the same issue. Got a warranty replacement. That had probs so I went to menu, wireless networks, mobile networks, access point names, reset to default. That worked for a little while. Called back today and am waiting on an analyst to call me back. I may be given a different device.
4g -> 3g -> 1x
By Rufus 01 in forum Verizon LG RevolutionReplies: 0Last Post: 08-16-2011, 01:43 PM -
network issues? nonstop switching among 4G/3G/1x
By diablofreak in forum Verizon HTC ThunderboltReplies: 6Last Post: 07-12-2011, 04:28 PM -
4g/3g Data Connection Problems in the Wilkes-Barre/Scranton
By TCCDROIDMAN in forum Verizon HTC ThunderboltReplies: 0Last Post: 07-08-2011, 07:48 AM -
Thunderbolt reboots in 4G, 3G, 1X or WiFi?
By Chrisy in forum Verizon HTC ThunderboltReplies: 38Last Post: 06-09-2011, 06:50 PM -
4G 3G 1X
By gunmetalgr3g in forum Verizon HTC ThunderboltReplies: 4Last Post: 04-16-2011, 10:24 PM
Reply
