Results 1 to 3 of 3
    Default Unrooted for ICS Help
    Hey guys I un-rooted my tbolt. I am trying to update it to ICS and it will not. Keeps saying "Service Unavailable" Could this be because I now have a Samsung G III? If so is there anyway to get ICS on it.
  2. #2
    Unobtanium's Avatar
    Posts
    Global Posts
    206 Global Posts
    ROM
    Stock
    Default Re: Unrooted for ICS Help
    Quote Originally Posted by designwebs View Post
    If I understand your situation, you have a Thunderbolt that does not have a LTE SIM card in it; your G3 is the phone you swapped to from the TB. You can shut both phones down and put your G3 SIM card into your Thunderbolt (I think you need an adapter - the G3 has a micro-SIM, if I recall correctly). You SHOULD be able to do the upgrade, but others have reported some issues with un-rooted upgrades.
    Thanks for the reply. I will check into a sim card adapter...
  1. I'm hungry for ICS but i need help eating it....
    By killer-49 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-30-2012, 05:56 PM
  2. Please help, Hafta unroot for replacement
    By turp415 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-02-2012, 07:53 PM
  3. Unrooting for update help...
    By cajunbeast in forum Verizon Droid Incredible
    Last Post: 11-14-2010, 08:26 PM
  4. Berrybuzz for android??? HELP
    By hondaboi2000#ac in forum Android Applications
    Last Post: 08-23-2010, 12:54 PM
  5. UnRoot for 2.1 update?
    By jasonrellis in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 04-01-2010, 06:21 PM
