1. jdd77's Avatar
    As you can see in the picture, the battery is at 76% at about 8 hours after disconnecting from my home charger. Found a charger lying around at work and decided to plug it in for an hour. After disconnecting, (and to my surprise) the battery remained at 81% for 6 hours before I plugged it back in when I got home. The charger I use at home comes apart to double as a usb cable. The one I used at work does not. After this incident, I am wondering if the type of charger used makes a difference in battery life, or was my Tbolt just being nice?
    Note: phone usage was the same throughout the day (a couple e-mails and texts, occasional web browsing).
    04-03-2013 09:01 AM
  2. meyerweb#CB's Avatar
    A different charger might charge the battery faster, by a little bit, but it will have no influence on what the battery does once it's unplugged. And whether the cable disconnects or not doesn't make any difference, either. It looks like the major reason for the slow drain is that you didn't use the phone much.
    04-04-2013 08:33 PM
  3. jdd77's Avatar
    Thats why I posted this-I didnt use the phone much the whole day and the difference in battery drain after 1 hour charge is astounding. I work 12 hrs. and as you can see in the pic, the heaviest use was in the first 2 hrs. before I left for work. The next 5 hours I hardly used it but the battery steadily dropped before I charged it agan, for an hour. The last 6 hours on battery the phone remained at 81% with the same light usage as the prior 5 hours. In fact, as you can also see in the pic, the awake and screen on times were a little bit more in the last half of the day. My question is: if I didnt use some mega-super phone charger, how could this be?
    04-05-2013 09:16 AM
  1. Battery life when using just 4G
    By steve0617 in forum Verizon Galaxy S III
    Last Post: 11-02-2012, 07:54 PM
  2. 6hr Battery Life, OS using 40%????
    By racermech in forum Motorola Droid
    Last Post: 09-13-2011, 10:18 PM
  3. Strange Battery Life When Unplugged
    By qfnol31 in forum HTC EVO Shift 4G
    Last Post: 01-11-2011, 03:53 PM
  4. Awesome battery life when battery charged separate
    By Jerzyiroc in forum HTC EVO 4G
    Last Post: 07-12-2010, 04:43 PM
  5. Battery Life when on 3G and low signal
    By yanks4life in forum HTC EVO 4G
    Last Post: 06-29-2010, 02:22 PM
