Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
  1. #26
    nate44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Synergy
  2. #27
    SHO95#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    For me is fine. Way better than mt Fascinate.
  3. #28
    AndroidXTC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Default
    The low power button is unfortunatly normal for this handset. The EVO was the exact same way with just as many complaints just do a search in that forum. Its a shame it fell on deaf ears over at HTC.
  4. #29
    Forgetful's Avatar
    Energy hoarder
    Posts
    Global Posts
    1,473 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock rooted
    Default
    Quote Originally Posted by xrussx View Post
    My first bolt had a sticky power button along with other issues. New one is fine.
    Sent from my Thunderbolt.
    I sorta have the same thing too. My button occasionally gets stuck in the on position. I'm hoping it for a away with time
  5. #30
    CallerHoller's Avatar
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    The size of the body makes it hard to find for me. It's about 4mm to the left of my OG Droid. It's so flush with the body I feel I have to search for it when I need to push it.
    I'm also pressing the volume rocker, with my thumb, every time as the screen comes on.
  6. #31
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks. Merged.
  7. #32
    i colossus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    lol i dunno why people find this annoying. i like it being flush it looks better. and it stops from accidental pushes. aka it does what it's supposed to do.
  8. #33
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by i colossus View Post
    A little weird that this is funny enough to make you Laugh out Loud. I never had an accidental button push on my OG Droid in a year and a half.
  9. #34
    YourMobileGuru's Avatar
    Formerly VZWRocks
    Posts
    Global Posts
    4,283 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    what's wrong with stock?
    Default
    It looks nicer, true, but if you power-cycle your phone often it will get old really fast. I did notice the TB has an option I have never seen before that allows you to restart the phone rather than shut it off then have to turn it on again (saving yourself having to press the button again.
  10. #35
    k8t
    k8t is offline
    k8t's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I had this problem too. When I first put on the cover, the power button sticks out as it should but when I press it, it doesn't spring back up to it's original position. I removed the cover and the button goes down and springs back up as normal. In its mushed down state, I have a very hard time activating the power button to turn on/off the screen. I think some Thunderbolts have a defective cover.
    I showed it to the VZW reps and they said it was normal and I have to live with it. I then proceeded to just return the phone and all accessories (I only had it for a few hours). That's when the rep said they could replace my phone instead. The new phone has a properly working power button now.
  11. #36
    djcyph's Avatar
    Posts
    Global Posts
    378 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    not flush against the phone for me...it does seem a little angled..like 1 side is lower then other..and i didnt notice till this thread ha....
    but button seems to work perfectly fine for me
  12. #37
    i colossus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by CallerHoller View Post
    you don't lol?
    i never had that problem with my og droid either. but remember how it is designed on the droid? flush on one side then downed on the other side. and i mean like accidental in the pocket killing your battery because the screen keeps going on.
  13. #38
    SilentRunner05's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I too have this problem and I find it to be annoying. I am sure I am not the only one that looks at there phone constantly and I seem to have to find the sweet spot to wake the phone up or lock it..I have the extended battery and I think its much worse with the extended battery cover....It was not so much a issue with the standard battery and battery cover on...
  14. #39
    devindpotts's Avatar
    Posts
    Global Posts
    37 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Talking
    Quote Originally Posted by SilentRunner05 View Post
    I had this problem exactly and I am with you it was very annoying. Eventually my power button would flat out get stuck. I had to pop the cover off so it would spring back out. I also had really bad gaps at the bottom of the screen with bad light leaks. I exchanged mine and the one I have now is flawless. Seeing many of them have this issue I don't know if it's worth the risk for you to exchange it out or not, but I'm glad I did. It seems like some people are getting cosmetically messed up phones while others have no issues at all. It sounds like some of the batches where put together on a Friday night at 5:25 by a guy that was more concentrated on getting off work. .
  15. #40
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I had to exchange my TB cause of random restarts. My new one has a much better power button. Presses better without having to reposition my hand. Weird that each TB is different.
  16. #41
    dequardo#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Second time I've read of HW differences among early batches. There's really NO bottom gap on some but not most? And the power buttons differ? O the one I returned it just barely sat above flush.
  17. #42
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by devindpotts View Post
    I am not interested in exchanging mine because its not really a problem...I just have to find the sweet spot majority of the time....If I had the issues as you did with the light, hell I would be exchanging it myself...but this is and the battery are my 2 major concerns...Now that i have the extended battery, I am still on my 2nd day on one charge with moderate use...I got 14 hours with HEAVY use on one charge...
  18. #43
    Posts
    Global Posts
    37 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Wow now that is impressive. I am thinking about taking the plunge and getting the extended battery. I will probably wait to find out if the multimedia dock will be able to hold the phone with the extended battery on. I don't want to have to pull the battery out each night before bed. Does the extra bulge bother you too much?
  19. #44
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have a car doc and just have to put it away until I need to use my GPS. It adds some weight but that is ok...I do not mind I prefer a heavy phone in my hand and I can keep the 4G on...I was getting 4-6 hours tops with the standard battery...last Friday I had to charge it 3 times in one day and had enough...I figured if I wanted the 4G I had to go with the bigger battery....
  20. #45
    usmcO3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Power button doesn't "stick out" enough
    Do anyone know where I can send my HTC Thunderbolt phone or take it to get the power button replace?
    Pls help
