12-26-2012 03:35 PM
45 12
tools
  1. vdefender's Avatar
    I picked up two TB's yesterday morning, and after a few hours of use, I noticed that the power button on one of them sits significantly lower is its hole than the other. And when I say significantly, I mean that it is Flush with the case and doesn't stick up at all.
    So since I only have two phones, one with a button that sticks out, and one that doesn't. Which is normal?? I assume that I just have a defect and the button should stick out more. It's kind of a pain to push it to turn the screen on.
    Thanks!
    03-18-2011 04:54 AM
  2. AndroidXTC's Avatar
    Mine is flush too. With use they sink. The Evo has the same issues.
    03-18-2011 05:26 AM
  3. superlawyer15's Avatar
    does it continue to work properly?
    03-18-2011 05:34 AM
  4. AndroidXTC's Avatar
    For the most part yes
    03-18-2011 06:16 AM
  5. rjpear's Avatar
    Same issue here with the Low Power button.. The Best Buy Guy Questioned it when turning it on... and the other guy said he didn't have an issue with one he did earlier.. but of course I walked out with the Fubared Power Button..Grr...
    03-18-2011 06:33 AM
  6. DJBeanPole's Avatar
    Thats what she said.
    Mapex and TeckSupport05 like this.
    03-18-2011 06:47 AM
  7. vdefender's Avatar
    I wonder if I can take it apart and bend the metal spring out more? I'll wait for an iFix-it tear down guide
    03-18-2011 02:26 PM
  8. Forgetful's Avatar
    I wish it was the same button the Dinc has...
    03-18-2011 02:30 PM
  9. bmcclure937's Avatar
    My solution... the matte black silicon case from Verizon works great for pressing the button. My philosophy is that it probably does not abuse the button as much as if you needed to jab at it to try to wake your device.
    The case has a raised portion where the button sits and has a contact to press into the button. This has worked well and without any issues for me
    03-18-2011 02:36 PM
  10. AndroidXTC's Avatar
    Unless you really know what you are doing I wouldn't take it apart. This is a common problem on the Evo, even the high ones when new after a month or so settle into the frame not sure why. You can see the switch well by just removing the battery door.
    03-18-2011 02:36 PM
  11. AndroidXTC's Avatar
    Here is where mine sits and I would consider this as normal. My Evo is abouut the same. Click pic to enlarge.
    03-18-2011 03:05 PM
  12. vdefender's Avatar
    Yep thats about how mine is. But the other TB a bought yesterday sits way higher! Well it did as of yesterday. I'll have to take a look at it when it comes home later today to see if its use today set it back down.
    03-18-2011 03:08 PM
  13. Cory Streater's Avatar
    I noticed this on the TB at CES. I was hoping they were going to fix this before the final release
    03-18-2011 03:12 PM
  14. prakash99's Avatar
    I didn't have much of a problem with power button with DInc and on TB I don't have any problems powering off. But I have to hit the button a few times before I get it right and the phone starts powering up. So far that has been my ONLY problem with the phone. Battery life is not exciting but I was mentally prepared for that and is not one my complaints.
    03-18-2011 03:44 PM
  15. AndroidXTC's Avatar
    I have this issue also. What I found was you really have to hold the button down for a good long time before the power up sequence starts for some reason.
    prakash99 likes this.
    03-18-2011 03:50 PM
  16. aplsucks's Avatar
    i was thinking it is kinda low too. Not the easiest to press sometimes.
    03-18-2011 04:18 PM
  17. zionarbadon's Avatar
    I had the same problem with the power button being very low, but mine was to the point where it was not pressing in. It was simply an issue of the best guy snapping the back on in a way that made the button flush. I snapped the back on a few times (trying to come from the bottom) and now it works fine.
    03-18-2011 04:32 PM
  18. Sal's Avatar
    Mine seems to be a little lopsided. The power button is a little raised on its right, as you face the screen, but is flat/flush on the left side. Anyone else notice this? I'm happy with the phone otherwise so far, after a day's use. Would anyone take it back for this? I do have to press it more deliberately than my old Droid1 to get it to function...
    03-18-2011 04:44 PM
  19. AndroidXTC's Avatar
    Yes mine too and I think this is due to the fact I bet the real switch button under the outer button is not in the center of the outer casing but to one side. I wish HTC would benchmark the IPhone4 it has the best switch gear I have ever seen on a phone. Thats the thing with Apple they really sweat the details to make it right.
    03-18-2011 04:50 PM
  20. YourMobileGuru's Avatar
    Including the faulty antenna? ;-) LOL ... no thanks I like to actually use my phone to make calls from time to time...
    03-18-2011 07:23 PM
  21. dequardo#AC's Avatar
    I think it's a tough call here. They can't raise it too high or it will be hair trigger with cases that cover the button and have a nub on the underside. I bet there is a lot of discussion on this design aspect.
    03-18-2011 09:54 PM
  22. scottadusa's Avatar
    One thing i do not like is the small little almost invisible power button.
    Anyone notice how hard it is to hit it sometimes. Its almost below the surface of the phone/
    03-19-2011 01:14 AM
  23. xrussx's Avatar
    My first bolt had a sticky power button along with other issues. New one is fine.
    Sent from my Thunderbolt.
    03-19-2011 01:17 AM
  24. mikec5z06's Avatar
    They swapped the phone without any issue?
    03-19-2011 01:19 AM
  25. xrussx's Avatar
    Had the button light leak. Best buy swapped it. I showed them they said ok.
    03-19-2011 01:23 AM
45 12
