1. heartagram616's Avatar
    the problem is i don't know what it is exactly, under ALL in the manage apps section it is "PVWmdrmService", does anybody know what that might actually be? when the phone starts up it is running and my phone lasts like 6 hours just sitting even less if I use it. I force stopped it and I am now at about 16 hours unplugged and 68% battery left. If it is something I can delete I would love to but I have no clue what it is. HELP? thanks in advance
    Casey Cheung likes this.
    03-20-2011 02:00 PM
  2. BigMace23's Avatar
    This happened to me too... it has something to do with the blockbuster app. If you open that app, update it to the newest version, and then turn off automatic syncing in its settings it'll turn that service off. Or you can root and remove blockbuster altogether
    03-20-2011 02:06 PM
  3. lovy's Avatar
    hmm I see it running all the time in mine even when in idle battery goes down I would love to hear the response to this. Do you notice a change now that you have forced stopped it?
    03-20-2011 02:07 PM
  4. Rem's Avatar
    Yep, this is related to the Blockbuster app. There's more detail about it in this thread.
    heartagram616 likes this.
    03-20-2011 02:08 PM
  5. Nidaja's Avatar
    Can't you just force close these apps that HTC installed?
    03-20-2011 02:11 PM
  6. krazy's Avatar
    No, not really.
    03-20-2011 02:11 PM
  7. heartagram616's Avatar
    thanks for all the quick replies that is why i absolutely love this community, to the mods i guess you can close this thread down.
    thanks again everybody
    03-20-2011 02:13 PM
  8. realitydigg's Avatar
    You can force close it, but it will start up if the system thinks it is supposed to be running. Better to do the fix
    03-20-2011 02:20 PM
  9. mlee21's Avatar
    By turning off automatic syncing, do you mean disable movie updates? I dont see an automatic syncing option.
    03-20-2011 03:13 PM
  10. Joelist's Avatar
    Actually Verizon added the extra apps not HTC.
    I also did the process to discontinue updates on it and battery life jumped.
    03-20-2011 03:28 PM
  11. lazymac's Avatar
    Wouldn't that be great if the whole source of these battery issues is because of a crappy app forced on by a dying company? I wonder how sales have suffered because of battery concerns.
    03-20-2011 03:31 PM
  12. lazymac's Avatar
    Just disabled auto updating from within the app also and will report back how it behaves.
    03-20-2011 03:37 PM
  13. Joelist's Avatar
    I'm quite sure sales have not suffered. All reports have been that the launch was super successful.
    Also, remember that the large majority here even are not reporting battery life issues. It is a small portion of a small portion (as posters here are a small portion of the universe of android users) that are complaining vociferously.
    03-20-2011 03:38 PM
  14. Kmasum's Avatar
    My number one problem with battery drain is 4g radio
    Sent from my Bolt using Tapatalk!
    03-20-2011 04:17 PM
  15. Raptor007's Avatar
    With Blockbuster going under why the hell is it installed to begin with. I realize that they may survive in some form or fashion but seriously put Netflix on there. I haven't touched that app and won't until I can get rooted.
    03-20-2011 09:18 PM
  16. J-Dam's Avatar
    It keeps showing up on my phone even though i have canceled updates and force closed it. Disappears for about an hour and then shows up.
    *shrugs*
    03-20-2011 09:26 PM
  17. krazy's Avatar
    I deleted everything I could off my phone, turned off every setting, turned the screen as low as I could and the battery life is much better. Now I'm going to start turning things on one by one and measuring the difference from the base. I'll keep you guys updated.
    03-20-2011 09:27 PM
  18. Dgomez242@comcast.net's Avatar
    I dont understand this at all. It does not show up in my battery management at all. However, it shows running in the running services menu. In fact it shows that it has been running for 4 hours straight, yet it still does not show in the battery management.
    I have been getting excellent battery life since I got the phone too. I wonder why it is draining battery on some phones while it does not on mine when it is clearly running non stop.
    03-20-2011 09:50 PM
  19. msf316's Avatar
    My bettery life is bad to. I had to go pick up the extended battery. Its a little bulky but not that much. I can live with it. Today is my first day with it. So ill see how it goes tomorrow.
    03-20-2011 10:59 PM
  20. Elizabeth Cameron24's Avatar
    Why is android system running my battery down and wont let it charge
    05-06-2013 11:53 AM
  21. Elizabeth Cameron24's Avatar
    05-06-2013 12:10 PM
  22. quickdraw86's Avatar
    Posting a picture of your battery usage would provide more insight into your problem. Android system will ALWAYS run in the background on your phone, and will be one of your largest battery drainers if you don't use your phone much. Excessive battery drain could be symptomatic of installed apps that are set to sync too frequently, a bad battery, etc. If you're running a custom Rom on your device, there could be issues there. If you don't know what a custom Rom is, don't worry, you're stock.
    05-07-2013 09:40 PM
