Results 1 to 21 of 21
    Air Force One's Avatar
    Posts
    Global Posts
    587 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Apps That Cause Unusual Battery Drain: Post Them Here
    I posted this in the tips thread but was afraid not may would see it(you know how stickies are)
    I just found an app killing my battery: Flickie HD Wallpapers. I actually downloaded this app several days ago but had not opened it and accepted the terms. Well yesterday I got GREAT battery life, but today it was draining right before my eyes. I looked and looked but couldn't find the issue until I finally checked Spare Parts under sensor usage, and there it was... Flickie running some kind of sensor ALL DAY LONG. I knew right away that was it because before I went to bed last night I opened it, accepted the terms and looked at some wallpapers. I've deleted the app and already I'm back to normal battery drain. I think the sensor has to do with the way it uses the gallery and the pics tilt back and forth as you tilt the phone.
    maybe this thread could be a good place to post and warn each other about apps that like to kill battery life in a rogue manner.
    lovy and samuraifortruth like this.
  2. #2
    thedeceiver's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yahoo Mail.
    Sent from my ADR6400L using Tapatalk
  3. #3
    Kronko's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Friend Stream is one of them.
  4. #4
    babybrownz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    how do you cancel friend stream?
  5. #5
    shley00's Avatar
    Posts
    Global Posts
    96 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Kronko View Post
    Even if you update every .4 hrs ?
  6. #6
    J-Dam's Avatar
    Posts
    Global Posts
    294 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by thedeceiver View Post
    Yahoo Mail.
    Please explain. I have it to only sync when i choose. Am i missing something?
  7. #7
    krazy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Phone
    Gmail
    Navigation
    Internet
    YouTube
    Market
    People
    Music
    Clock
    Weather
    Camera
    Camcorder
    Calendar
    Calculator
    Slacker Radio
    News
    and Blockbuster.
    Oh yeah, and standby as well if you count that as an "app".
  8. #8
    oma1340's Avatar
    Posts
    Global Posts
    43 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Friend Stream
    Can anyone tell how I delete Friend Stream??? Step by Step... and if I do delete it can I still use Facebook? Thanks!
  9. #9
    FutureTBoltOwner's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Friend stream is a huge user of battery, I was doing okay for the first couple of days but noticed my battery was terrible today, so I decided to finally ax the friend stream and instead opt to use the facebook app when need be ... great decision I charged it up and now have been off charger for about 3 hours and have only lost about 15% on my battery
    The way I believe I killed friend stream for those that are interested is as follows:
    1. open settings
    2. go to applications
    3. go to manage apps
    4. click running at the top (2nd out of the 4 at top)
    5. find friend stream and click
    6. force stop (i just looked at my stream says last update was at 12:42 this afternoon over 9 hours ago so i think its safe to assume it has been stopped)
    7. and that should be your solution to negate friend stream and improve your battery, hope you have success with it like i did
    oma1340 and Air Force One like this.
  10. #10
    Kevin OQuinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    9,910 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    If you have tips and tricks for battery life they need to be posted in the sticky.
    If you have questions about removing stock apps those need to go in the appropriate thread. If you can't find a thread about it already then create one in the hacks section.
    Friendstream uses battery because it polls for Facebook updates. You can set it to not do that in the settings.
    samuraifortruth likes this.
  11. #11
    oma1340's Avatar
    Posts
    Global Posts
    43 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Was wondering if there is a way to remove the Friend Stream completely from the screen it is on? Otherwise that screen remains there and you are not able to put any other apps on that screen. Thank so much!
  12. #12
    paulmike3's Avatar
    Posts
    Global Posts
    1,423 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by oma1340 View Post
    Press and hold it, then drag it to the remove area in the bottom right.
  13. #13
    shaddix's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I use lp's fb/Twitter widget with manual updates only
  14. #14
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Sighlense View Post
    If you have it do the "Push" mail thing... it will EAT your battery. It works great but it's a battery killer.
  15. #15
    canesfan44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I set Friendstream to only update every 12 hours, it doesn't seem to effect my battery very much at all, then again, I could really care less about facebook, and others, my ex-girlfriend is the one who signed me up for it. If I want to know what my friends are up to, I just call them.
  16. #16
    upz3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    It's amazing what stupid things run. About 10 of my apps were running when I never turned them on since reboot. Really horrible when you think about it. Like I really need PayPal turned on all the time.
    I don't even have FriendStream being used or connected to any account and it still runs.
  17. Thread Author  Thread Author    #17
    Posts
    Global Posts
    587 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I accidentally opened the bloat-ware app tunewiki tonight. Didn't touch my TB for three hours come back and it's almost dead. I check spare parts and my TB has been awake the entire time. Under partial wake usage I find tune-wiki has kept the TB awake ever since I opened it. I finally had to reboot to get that damn app closed. I don't suggest using that app. When I root it's the first thing getting deleted.
  18. #18
    KenDroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BAMF Soab/3++
    Default
    Words with Friends! Playing it period drains the battery. It also defaults background notifications to 5min! Change it to "Never" in the account settings and that helps alot when you're not playing.
  19. #19
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    7,532 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BB JB
    Default
    You can't. It is a required app even when rooted. Just don't use it and it shouldn't load. At least on the dinc that's how it is.
    sent from the phone Phil hates via tapatalk
  20. #20
    prakash99's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    GummyNex 0.3.8
    Default
    Friends Stream is not much of a drain if you reduce the frequency of updates, which I have set to once a day. I would have set it to manual but that is not an option.
    Any live wallpaper is a major battery drain, so I stay away from those. And also any auto task killers. Don't install those if you want to conserve battery.
  21. #21
    lovy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Would like to know if wordfeud or words with friends drain battery. Asking because I don't know how to exit either of them. Is the back button sufficient?
