03-28-2011 10:33 PM
175 1234 ...
tools
  1. alfieferenzo84's Avatar
    Please charge your battery and before it dies do the below and post your results. I am trying to get a idea on battery life or is mine just bad before i go returning or exchanging it
    Please post your results Thanks
    Menu-settings-about phone-Battery
    Please post your up time and your awake time.
    I get about 2-4 hrs of awake time. Yeah if i leave the phone alone i can get a weeks worth of up time and i think everything is mixing it up. The awake time is what matters. Htc said 6hrs im getting half of that.
    IF YOU DONT RESTART YOUR PHONE THE NUMBERS WILL NOT RESET AND THEY WILL BE WRONG.
    Thanks again
    03-23-2011 01:34 PM
  2. ShaggyKids's Avatar
    I will have to give you my results after charging which won't be until after 9p tonight. I didn't know this was here cool. I like the "What's been using my battery" and I find 79% of mine is the Display. The rest are all EXTREMELY minimal. What exactly is "wake time" ???
    03-23-2011 01:39 PM
  3. alfieferenzo84's Avatar
    wake time is when you are using the phone.
    People are saying there phones last 2 days but thats because there awake time is 1hr. lol
    You should get 6hrs of awake time. I get 2-4hrs
    03-23-2011 01:44 PM
  4. ShaggyKids's Avatar
    Mine's currently showing 4:46:26 so I guess I'm doing ok but I'm wishing I could plug it in for 24 hours and see what happens. I've only been quick charging it, prolly 6 hours charge at the most and bump charging in between if needed.
    03-23-2011 01:50 PM
  5. alfieferenzo84's Avatar
    Oh you have to restart your phone or these numbers will not be correct... So charge your phone and reboot it and go on with the day. Before it dies write it down or post it real quick
    Thanks
    03-23-2011 01:57 PM
  6. alfieferenzo84's Avatar
    No because if you dont restart your phone the numbers will not reset so if you keep your phone on for a week i bet you will have 20hrs or more of awake time....
    03-23-2011 01:58 PM
  7. Mordecaidrake's Avatar
    I unplugged my phone at 6am this morning it's 2:04pm now, I spent 10 minutes on the charger moving a file and I'm at 60%. 70% is display the rest is under 6%. I've been doing some browsing, and I watched a 10 minute video. Looking good for me. It's doing good for me...
    03-23-2011 02:06 PM
  8. alfieferenzo84's Avatar
    Please post your awake time and % of battery. Saying what you did dont really help
    03-23-2011 02:17 PM
  9. Mordecaidrake's Avatar
    Awake time 5hrs 43 minutes 60% battery life remaining.
    03-23-2011 02:19 PM
  10. alfieferenzo84's Avatar
    Did you restart the phone after it was charged? If you dont restart the phone then the timmer keeps going up so that could be the last 5 charges worth...
    I cant get more then 4hrs awake on mine doing nothing i cant belive your getting 5hrs doing things and still be at 60%
    03-23-2011 02:20 PM
  11. Fillyo's Avatar
    Awake time of 7.5 hours and am at 63%. Light to moderate use.
    03-23-2011 02:21 PM
  12. alfieferenzo84's Avatar
    You didnt restart after charge htc said only 6hrs so no way your getting 7.5 hrs
    03-23-2011 02:22 PM
  13. Mordecaidrake's Avatar
    I restarted it last night before bed because I wanted to get a fresh Quadrant score.
    03-23-2011 02:22 PM
  14. alfieferenzo84's Avatar
    Then it sat on the charger so if you restarted at 12 and took off the charger at 6 then minus 6hrs off your awake time as the awake time runs while charging.
    1hr and 30min of awake time my phone would read about 60-70 % so sounds about right
    03-23-2011 02:28 PM
  15. alfieferenzo84's Avatar
    Once again you must charge your battery then restart or the awake time will not be correct and pointless to post.
    Thanks
    03-23-2011 02:28 PM
  16. rmciver's Avatar
    under apps, clicked phone info, it says I have went 18+ hrs since last charge. I have used the TB all day today using the web, txting, phone. Also downloaded 2 pdf files. Which downloaded FAST!!!!
    03-23-2011 02:29 PM
  17. alfieferenzo84's Avatar
    Thanks but you need to fully charge it and then unplug, restart the phone and go on with the day. If you plug the charger in or restart it again then the test will not be correct...
    03-23-2011 02:37 PM
  18. tarheelDan's Avatar
    Sounds like you would like us to:
    1. Fully charge Bolt
    2. Reboot
    3. Use as normal, do not charge
    4. Post awake time from settings->about phone->battery when the battery is almost dead.
    Gonna try this tomorrow, I'm curious.
    alfieferenzo84 likes this.
    03-23-2011 02:50 PM
  19. alfieferenzo84's Avatar
    2. Reboot
    PERFECT
    I guess i should of wrote it like that
    Thanks
    03-23-2011 03:17 PM
  20. SoldierofCatan's Avatar
    59%
    Up Time = 5:47
    Awake Time = 2:08
    Display is at 76%
    EDIT*
    Forgot to mention that I did a battery calibration this morning. This is much better than yesterday. At this time yesterday I was all ready dead and charging it.
    03-23-2011 03:25 PM
  21. alfieferenzo84's Avatar
    59%
    Up Time = 5:47
    Awake Time = 2:08
    Display is at 76%
    EDIT*
    Interesting...
    My screen is all the way down. All updates and push are off. Im on 3g only turned off 4g
    Im pretty close to your awake and up time but i have about 20 more min of awake time and im at 40%
    20% difference but my screen is all the way down. I know when i first got it the screen was half way and that had a major inpact on time i was getting 2hrs max...
    I think i should call verizon and exchange it and try a new one, I just wanted to see what others are getting because i dont want to deal with exchaning.
    03-23-2011 03:42 PM
  22. Mike_is_Mike's Avatar
    I've got 6 hours and 29 minutes of wake time on my first charge of the Seidio 1600 battery.
    7 hours and 46 mintues of up time and still 40% showing on this first charge.
    03-23-2011 04:10 PM
  23. Mike_is_Mike's Avatar
    That is wrong. You do not have to restart/reboot your phone to reset these numbers. The numbers are from your last "unplugged." It says so right on your phone.
    itsdollar likes this.
    03-23-2011 04:12 PM
  24. Mike_is_Mike's Avatar
    WAY. I've got 6 hours and 34 minutes so far today. I know this because I have been watching it all day. Two plus hours of that were watching a downloaded movie from Bluckbuster.... unplugged, of course.
    How many times have you charged your battery? What are your settings? Do you bump charge?
    03-23-2011 04:16 PM
  25. Mike_is_Mike's Avatar
    Interesting...
    Maybe you have a defective battery.
    03-23-2011 04:17 PM
175 1234 ...
