Results 1 to 17 of 17
    htowngator's Avatar
    Posts
    Global Posts
    1,226 Global Posts
    ROM
    CM 10 KANG
    Default 4G power usage truly is the problem
    Had wifi on with the phone off power at my house and moderately using the phone. After 6 hours, I had only 25% battery loss. Normally when I go to work I don't even get a chance to mess with my phone much so it's just standard battery drain on idle -- usually 10% per hour. 4G LTE truly takes a ton of battery and I know it's beating a dead horse here, but just wanted to relay my findings. I think that if/when they release a true 4G toggle or improves the efficiency of the LTE chip, we will see a dramatic improvement.
    Thanked by:
  2. #2
    Effenhimer's Avatar
    Posts
    ROM
    Stock, (for now)
    Default
    I live in a 4g area, and I get about 14 hours of moderate use between charges... I don't use wifi... I don't notice a drain anymore now that my battery has cycled and adapted to my use. I do have background sync off still, (Google sync is always on, and GPS) but I don't need FB and the like to sync unless I'm using it.
    I did on accident hit the friendstream icon in the app drawer and not turn it off the other day... Went from 96% to 39% in 2 hours.
  3. #3
    Default
    A toggle would be nice, but until then I don't mind using that Phone Info app and doing it manually.
  4. #4
    Default
    I've tested wifi, 3G (usually 1-2 bars), and 4G (usually 1-3 bars), and while wifi adds a bit of battery life, the only conclusive battery draw on my device is the display.
    I've gotten 12-14 hours of battery when I hardly use my TB sitting in low 4G signal area all day, and less than 3 hours when I use it nonstop (even with little network traffic). The display is always at 75-85% of the battery usage, and I keep my brightness at 16%, with auto off and a dark wallpaper.
    IMO, any power management fixes need to be on the display, not the radio(s).
    htowngator's Avatar
    Posts
    Global Posts
    1,226 Global Posts
    ROM
    CM 10 KANG
    Default
    Quote Originally Posted by Effenhimer View Post
    I wish I knew how you got that much time on your device. I would get maybe 11 hours if I didn't touch the device at all and just let the cell/radio standby run all day. I once had those two combine for 35% and my display was 60% (5% other). That's crazy.
    I live in a strong 4G area (usually 3 bars if not 4) as well and it never switches back and forth to 3G/4G.
  6. #6
    Default
    depends on how much you use ur phone. When I am at school in or at work I really dont get to use my phone alot. I put it in 3g mode and works great. I still have 70% battery life left after 7 hours it has been off charger already. I think overtime they will probably make improvements to the 4g battery life but for now when I have no need for 4g I turn it off.
    htowngator's Avatar
    Posts
    Global Posts
    1,226 Global Posts
    ROM
    CM 10 KANG
    Default
    Anyone have the link to the specific app that enables the toggle?
  8. #8
    Default
    Quote Originally Posted by paulmike3 View Post
    I agree. I keep the display cranked down really low 15-20% and every time I check the use stats screen is number one by a factor of ~2-3!
  9. #9
    mfancy's Avatar
    Posts
    Global Posts
    173 Global Posts
    Default
    Had WiFi on all day on my phone yesterday, my phone lasted all day with no problem.
    Had 4G on today, my phone was at 43% in 3 hours and it sat in my pocket for all but 3 minutes when I talked on the phone.
  10. #10
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,134 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Default
    Quote Originally Posted by htowngtr View Post
    It's called Phone Info and is available from the Android Market.
  11. #11
    Default
  12. #12
    johndabeast's Avatar
    Posts
    Global Posts
    201 Global Posts
    ROM
    Gingerbread DeBloated
    Default
    I just wanted to throw this out there, took my phone off its charger at 4 am, last night/this morning, and woke up at 12, the cell standby was at 35%, along with the phone idle also around 35%, the screen was way below at 12% (I was sleeping so it was never on) The overall battery percentage was 45%. I have no clue how this can happen with only email on my phone and the HTC weather/clock widget. Do I have a defective battery or something?
  13. #13
    Default
    This mirrors my results. I always get 12-14 hours of battery life with a similar usage pattern.
  14. #14
    jmeitz's Avatar
    Posts
    Global Posts
    121 Global Posts
    Default
    My Evo did the same thing when in 4g, doubt there is a fix for it other than a toggle or using the app. Unless gingerbread fixes it somehow.
  15. #15
    terrain's Avatar
    Posts
    Global Posts
    462 Global Posts
    Default
    I don't see any difference between 3G and LTE in battery hours. I do notice a very big difference in battery when tethering --- can drain my battery in a little less than 2 hours tethering LTE.
  16. #16
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    ROM
    Latest OTA Official ROM
    Default
    I live in/around 4G and I have not noticed any battery difference with 4G and/or 3G.
    -Frank
    [HTC Thunderbolt™ 4G/LTE!]
    It's not your dream phone. It's the one after that!©
    Look here for a [VZW Coverage Map] to check your area. Select 4G before hitting [Refresh]
  17. #17
    TBolt2011's Avatar
    Posts
    Global Posts
    689 Global Posts
    ROM
    Infected Eternity/stock
    Default
    That's a bit high! Mine is usually between 65-70% with moderate use with brightness at 35%, and a bright background of the California ocean.
    Thunderbolt Saga > Brett Favre Saga
