I keep on getting disconnected on my home router (D-Link DIR-825). I've done from both resetting the router (and the phone) to the activating the 5GHz tab to entering the static ip on the router page and phone. STILL won't connect or work. :'(
restart the router
if your network requires a password, double check you're entering the password correctly.
Restarted it, reset it, even restored it to factory default settings AND still no bueno.
call the cable company you may be dropping packets on their end
Some people have had incredible results with wiring fixer in the market. Just look at the reviews. I am not affiliated with them. Just looks like an apparently that works well.
Sent from my ADR6400L using Tapatalk
do you have any other devices on this router's network?
If so? do they get disconnected also?
Most routers can only handle X amount of devices. For mine it's 5
sent by MRO
Sorry but which one is that?
Right now, so far so good after I restarted all the phones, router, cable modem, and PCs. Hope this works now. (fingers crossed)
