Results 1 to 20 of 20
- 04-02-2011, 01:15 AM
Thread Author #1
- 04-02-2011, 04:42 AM #2
- 04-02-2011, 06:34 AM #3
- 04-02-2011, 09:25 AM #4
if your phone is charging u will have soild orange led and if u get a notification (if you have this option on) it will blink green to tell u u have a notification then back to orange to say its charging. also if ur under 25% battery life it will blink orange and again if u have a notification it will alternate to green.
Devices: Galaxy Nexus and Nexus 7 - 04-02-2011, 04:05 PM #5
Also, I read that if your battery is overheating, or you are in an error condition, it will keep blinking green/red until you turn it off/pull battery, or whatever is required to correct the situation.
-Frank[HTC Thunderbolt™ 4G/LTE!]
It's not your dream phone.
It's the one after that!©
Look here for a [VZW Coverage Map] to check your area. Select 4G before hitting [Refresh]Thanked by: - 04-02-2011, 04:29 PM
Thread Author #6
- 04-02-2011, 04:52 PM #7
- 04-02-2011, 06:03 PM #8
every application with notifications has this setting.
for example:
open the Gmail app.
hit menu
settings then scroll down u will see a check box for LED notification around where the you would select a ringtone an viberation.
repeat for any other app u wish to customize notifications for.
(Facebook, twitter, messages, ect)Devices: Galaxy Nexus and Nexus 7 - 04-04-2011, 04:28 AM #9
- 04-04-2011, 05:23 AM #10
But if you get below a certain percentage it will blink giving you a notification you are going into power saving mode. It will not do this if on the charger.^^^^^^
- 04-04-2011, 05:27 AM #11
- 04-04-2011, 08:46 AM #12
same here.
mine stays orange while charging, and will not alternate between email/text notification LED flashes and charging LED flashes...
it was about this time on my last phone (Evo) that someone discovered the extra WiMax notifier in the right corner of the speaker bar & created an app to flash that LED for texts while charging...now if only someone would discover the LTE comparable hidden LED on the TB
- 04-04-2011, 01:53 PM
Thread Author #13
- 04-04-2011, 02:05 PM #14
I had this happen when I had the mobile hotspot running while plugged in. And thinking about it now, it was crazy hot and was losing battery while plugged in. So it would make sense that it would be due to overheating. It seems kind of odd that a notification wouldn't pop up on screen though.
Moto V300 - Moto E815 - LG VX8600 - Moto Krave - Blackberry Pearl 8130 - Moto Droid - HTC Thunderbolt - galaxy nexus - 04-04-2011, 02:46 PM #15
The LED on this phone is pretty close to useless. It'd be great if it had more colors.
- 04-04-2011, 04:15 PM #16[HTC Thunderbolt™ 4G/LTE!]
Look here for a [VZW Coverage Map] to check your area. Select 4G before hitting [Refresh] - 04-05-2011, 10:17 AM #17
- 04-05-2011, 10:38 AM #18
- 06-07-2011, 01:10 AM #19
- 06-07-2011, 05:21 AM #20
Overheated battery is the winner.
Reply
