MojaveHigh
I have the smaller New Trent external battery pack and it works well. The one I have has a 5000 mAh capacity and I use it with both my Tbolt and my iPod touch. The one nit I have with the product is that it doesn't charge using a standard USB connection. If I had to do it over again I'd get one of the external batteries that charge using a standard USB cable.
I was just looking at the New Trent 5000mAh battery on Amazon and I don't understand what you mean, "it doesn't charge using a standard USB connection".
It has a mini-USB in so that you can charge the battery with a USB wall charger. And it has two USB outs, so you can charge any device that will charge via USB.
So, with my Thunderbolt, I could carry just the one mini-USB to USB cable and the USB AC adapter. I would charge the New Trent with the cable and adapter. Then use that same cable to charge my Thunderbolt from the New Trent. That seems really ideal. What am I missing?
