View Poll Results: Are you experiencing random reboots and if so what battery are you using?
Voters
68. You may not vote on this poll
  • Yes, stock battery (or additional battery)
    15 22.06%
  • Yes, the 2750 mAh extended battery from VZW/HTC
    14 20.59%
  • Yes Sedio
    1 1.47%
  • Yes, a cheap battery off eBay or elsewhere
    0 0%
  • Yes, a different extended life battery
    0 0%
  • No, I am not experiencing random reboots.
    38 55.88%
  1. YourMobileGuru's Avatar
    A little poll. How many of you who are having the random reboot problem are using extended life batteries?
    I saw someone else raise this question before but I think it got lost in the shuffle of discussion about the firmware and possible network issues. More people than average are using extended life batteries with the Thunderbolt and I was wondering of there was a possible correlation.
    * Yes, stock battery (or additional battery) -- this can be if you have two more more stock batteries and swap them.
    * Yes, the 2750 mAh extended battery from VZW/HTC
    * Yes, Sedio
    * Yes, a cheap battery off eBay or elsewhere
    * Yes, a different extended life battery
    * No, I am not experiencing random reboots.
    EDIT: For anyone using more than one please vote for the one it happens most on.
    05-23-2011 02:18 AM
  2. Maddog241's Avatar
    Nice idea! I personally am not having reboots at all. I use 2 OEM standard batteries and swap them as needed.
    05-23-2011 04:01 AM
  3. mrtonk's Avatar
    No.
    05-23-2011 05:48 AM
  4. bjboucher's Avatar
    No reboots here, using the VZW/HTC extended battery.
    05-23-2011 05:55 AM
  5. Chrisy's Avatar
    Reboots using 2750 extended.
    05-23-2011 06:14 AM
  6. mannw1977's Avatar
    I have extended battery. The issue happens with both ext. and factory batt.
    05-23-2011 06:55 AM
  7. saraheba's Avatar
    Reboots with stock battery. Averaging once per day.
    Sent from my ADR6400L using Tapatalk
    05-23-2011 07:02 AM
  8. karmajack's Avatar
    Riding stock everything here. Randoms occur about 2-4 times a day. Sometimes while I'm using it, sometimes when it's sittling there just charging. Girlfriend has TB without update, no reboots ever.
    05-23-2011 08:12 AM
  9. willymakit's Avatar
    Using Verizon stock and Verizon extended had lots of reboots after update,got a replacement phone no. problems since. YEA,knock on wood.lol
    05-23-2011 08:19 AM
  10. dpham00's Avatar
    Getting occasional reboots with ext batt , some days 1 or 2, sometimes 2-3 days wo reboot
    05-23-2011 09:13 AM
  11. WingsFan87's Avatar
    No reboots and no replacement
    Stock battery.
    05-23-2011 09:25 AM
  12. anon62607's Avatar
    2750 mAh extended battery and about 3-6 reboot a day
    05-23-2011 09:29 AM
  13. Edwill86's Avatar
    no reboots,on stock
    05-23-2011 09:47 AM
  14. Bill3508's Avatar
    Stock phone/stock battery, 3 reboots a day.
    Rooted phone running LTS 1.45/stock battery, 1 reboot so far since yesterday midday.
    05-23-2011 10:59 AM
  15. Mike_is_Mike's Avatar
    I don't see what the battery would have to do with reboots.
    I have the OM and a Sedio 1600 spare - no random reboots............... NOT rooted.
    05-23-2011 11:04 AM
  16. Goat-Tee's Avatar
    Stock battery and I said this before in a different thread, but my reboots always occur when my battery hits 50%. When draining and charging.
    05-23-2011 12:21 PM
  17. motodunner's Avatar
    Reboots with both stock and extended battery.
    05-23-2011 01:39 PM
  18. streetstrip01's Avatar
    Rooted without update, extended VZW battery. Had my first and only reboot today.
    05-23-2011 01:45 PM
  19. Verapakill's Avatar
    None here
    05-23-2011 02:24 PM
  20. jdk2's Avatar
    Reboots a couple of times a day minimum, often shutting off the phone while idle. Using the stock and extended battery as needed.
    05-23-2011 02:30 PM
  21. steve0617's Avatar
    Stock. 2750 extended battery.
    Rebooted once when clicking on an address in a text message and it was opening the map accessing data via 4g. Just turned off bit strangley went straight to the thunder sound effect not the HTC green logo.
    05-23-2011 02:51 PM
  22. Bats's Avatar
    No reboots here. Up 23 plus hour's.
    05-23-2011 03:05 PM
  23. YourMobileGuru's Avatar
    It would if somehow there were a short in the battery or of the batter door (extended life battery from HTC replaces the door) if one of the underside connections wasn't right.
    05-23-2011 09:23 PM
  24. YourMobileGuru's Avatar
    That's where I was only it was more like 4-8x a day. I have today and tomorrow off so I switched back to the stock battery to see if it made any difference. It still reboots but not quite as often and I am going on almost 8 hrs of uptime the best I have had in a while and the sound of my boot animation is back after the phone shut itself off earlier today for no reason. *shrug*
    EDIT: and it just rebooted after getting an email at about 7:53 uptime.
    05-23-2011 09:27 PM
