Page 1 of 2 12 LastLast
Results 1 to 25 of 30
    project.in.process's Avatar
    Posts
    Carrier
    Bamf Paradigm
    Default Display taking 88% power. thoughts?
    i've grown accustomed to the Display being the top battery consumer, but today i've noticed that it's exceedingly high.
    88%
    up time=5.12.48
    awake time=2.31.06
    other stats:
    cell standby=5%
    phone idle=3%
    androidOS=2%
    wifi=2%
    i've not kept my phone display 'on' longer than 10 seconds or so and haven't done any web browsing and my brightness is set to 25%.
    thoughts?
    i just flashed a new kernel last night--but before going the "it's a root problem", i figured i'd see if anyone has any other thoughts
  2. #2
    Beezzy's Avatar
    Posts
    Global Posts
    846 Global Posts
    Default
    4.3 inch screen, kinda need it on to do anything for the phone. Yeah it's gonna eat up most of the battery.
    Sent from my HTC Thunderbolt using Tapatalk
    Posts
    Carrier
    Bamf Paradigm
    Default
    Quote Originally Posted by BazzBro View Post
    while i do understand it could eat up the bulk of the battery--
    this much of a battery drop with that high % of potential culprit isn't something easy to overlook.
    usually it's sitting at 50-60% battery use. so that jump is what's alarming me.
  4. #4
    Default
    Well, it is just a percentage (all of them have to add up to 100 somehow). Perhaps you aren't doing a lot with your phone for other processes to be using much battery life at all.
  5. #5
    SoDev's Avatar
    Posts
    Global Posts
    1,035 Global Posts
    Carrier
    CM7 RC1.2
    Default
    Quote Originally Posted by gabbott View Post
    Good point. Hmm, that makes that stat a good thing. Would mean your phone is efficient.
    Mine is 65 screen 8 WiFi 6 dialer 6 cell standby. That's not better.
    Sent from the Bolt via Tapatalk
  6. #6
    Default
    Mine is 81% I have the brightness at maybe 1/5 if that. I don't really do much besides WiFi and I get great battery life on my bolt
  7. #7
    jstewart0131's Avatar
    Posts
    Global Posts
    84 Global Posts
    Carrier
    Gingeritis 3D v1.0 Beta 8
    Default
    Its a rolling percentage out of how much battery you have used. If you've done no data and haven't made any calls on the phone then you will likely see 85+% of the battery used by the screen. If you make an hour long call then the percentages will vary greatly. It is nothing to worry about IMO.
  8. #8
    Default
    If all you do is check your device for email and are not really using any apps that tax your device's CPU, then 88% for your Display is correct.
  9. #9
    Default
    You aren't looking at actual power consumed. It isn't practical or even possible to measure the current of every device and ever application. (how could you measure the 'current' that an app is using?)
    What that is is a measure is the CPU cycles. So 88% of you CPU time has been spent building the display screen.
    It likely does that, even if the display is off.
  10. #10
    Default
    I been having the same issue after the update where the display has been taking a huge % of my battery even if i haven't used the phone and i am talking about huge %. My battery could be down to 50% with very small use to sometimes none and it says is the display has taken about 80% thats like 40% of the battery with out even turning the phone on.
    This is not always an issue there are some days were i consume about 5% of battery per hour with moderate use. Then there are times where the phone gets really hot and just drinks up my juice a drunk out of rehad.
  11. #11
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    Carrier
    Latest OTA Official ROM
    Default
    Just to be clear, if you want to instantly lower your screen percentage by a noticeable amount, make a 1 hour phone call. You'll probably cut your screen use percentage down to 10-30 percent. It's just math folks!
    Basically, a high screen percentage figure means that you are not using your phone. You're just playing with it.
    -Frank
    zero neck likes this.
  12. #12
    Default
    Quote Originally Posted by FrankXS View Post
    Basically, I high screen percentage figure means that you are not using your phone. You're just playing with it.
    -Frank
    LOL... use your Smartphone as a PHONE!?!?!?
  13. #13
    rcpa's Avatar
    Posts
    Global Posts
    178 Global Posts
    Default
    I don't put very much faith in the numbers provided by the Battery Use screen. I don't believe it shows everything that is consuming power. For instance, when my phone goes off the rails and starts consuming 250-300 mA while idle on 4G (but not if I switch to 3G), I don't see anything different in the Battery Use screen. My phone at that point is chewing through the battery like crazy, and the Battery Use screen doesn't look any different.
    So, for finding a truly rogue app, the Battery Use screen might be helpful. But when the phone itself goes nuts and starts consuming battery while idle, this screen is useless.
  14. #14
    SoDev's Avatar
    Posts
    Global Posts
    1,035 Global Posts
    Carrier
    CM7 RC1.2
    Default
    Quote Originally Posted by fatboy97 View Post
    This thing makes calls too?! GTFO
  15. Thread Author  Thread Author    #15
    Posts
    Carrier
    Bamf Paradigm
    Default
    i suppose i should be more clear.
    the phone died within 5 hours of no use.
    i understand the % will add up to 100%, and if i had been leaving the screen on at full brightness for no reason and just tapping constantly for those 5 hours--then i could understand the battery dying & the screen being the reason.
    the screen being the largest consumer of battery life (according to battery stats) made me think it was the screen.
    that being said--5 hours of no phone calls & the phone dying is a bit suspicious.
    any way (spare parts?) to find out what has really been using the battery?
  16. #16
    Default
    Quote Originally Posted by project.in.process View Post
    So now you are going to say nothing at all is running in the background... no Facebook, Twitter, People, Weather, News, etc, etc, etc???
  17. Thread Author  Thread Author    #17
    Posts
    Carrier
    Bamf Paradigm
    Default
    no twitter (don't need it)
    people?
    weather only set to update manually upon opening
    no news
    no stocks
    gmail is set to sync
    facebook only set to sync once a day
    no bluetooth
    no gps
    3g signal
    gmail & facebook accounts are active.
    even at sync every 3 hours, i can't imagine they would drain the battery 100% in 5 hours.
    previous normal use on 3g is about 6-10% battery loss for me
  18. #18
    Default
    I will try this again. I will type slowly so you can read it better.
    You are NOT looking at power consumption. It is CPU cycles. You would get the SAME number at 100% brightness as you would get at 10% brightness. And maybe the same number with the screen turned off. In the background, it takes a certain number of CPU cycles to build the display. Even at 88% duty cycle for that portion of the CPU time to build the screen, it may mean nothing to actual current used. That is, one of the largest CPU time users may be the display, yet it may consume very little actual current.
    Actual hardware power consumption is not measured individually. The power may be going to the radio, the backlight, or the audio. You don't know. That screen is pretty worthless for determining what is using actual power.
    Again, you are NOT looking at actual current used, just CPU time.
  19. Thread Author  Thread Author    #19
    Posts
    Carrier
    Bamf Paradigm
    Default
    Quote Originally Posted by worwig View Post
    understood that, and since then i responded to a diff question about syncing accounts--so we're past that 'battery stats' screen being accurate
    and i will respond, slowly--and ask the sme question again
    is there an app to show what would is taking up actual power?
    (asked not being sarcastic or a smart-***)
    (spare parts or something--i've heard something used to see what processes are actually to blame for poor battery life)
  20. #20
    Default
    Omg everyone seems to be missing the whole point of the thread and are just trying to be smart asses. If the battery is at 5% thats a 95% of all the battery already use. The battery meter will tell you where that 95% of the battery when... 80% (of the 95%) was used on your display and the other 20% (of the 95%) else where to either phone idle, calls, OS... how the heck is the display not an issue? specially if you have not been using it?
    I understand that there is a meter running on up time and stand by so it calculates more than when you unplugged it. I have unplugged it and restarted the phone, roughly losing 4-6% of battery life with the reboot. This resets the counter and with that done i get the reading above ^^^^.
    Forgetful likes this.
  21. #21
    INK
    INK is offline
    INK's Avatar
    Banned
    Posts
    Global Posts
    466 Global Posts
    Default
    I would say make sure none of your apps are allowed to wake the screen. That happened to me before the SMS app was draining my battery hard due to the screen cosntatly being on and set the time out to liek 30 secs.
  22. #22
    rcpa's Avatar
    Posts
    Global Posts
    178 Global Posts
    Default
    Quote Originally Posted by Chepo84126 View Post
    What the others are telling you is that your assertion that the battery use screen tells you where that 95% of the battery went is wrong. They are saying that it only gives you the percentage of CPU cycles used for each of those things, not the amount of current drawn. Current draw by hardware components like the radio and backlight are not included in those measurements.
    For instance, increased power usage by the radio due to a weak signal will not be shown in those numbers.
    That screen is basically useless for figuring out where your battery is going.
    gabbott likes this.
  23. #23
    Default
    Sorry for my sarcasm. But there are so many people that believe that menu is actual hardware current used. I believe it is more confusing then it is helpfull.
  24. Thread Author  Thread Author    #24
    Posts
    Carrier
    Bamf Paradigm
    Default
    no worries friend
    i think i caught the problem.
    i downloaded another kernel this morning, flashed & since them i'm running about 5% battery loss/hour.
    i noticed, before switching kernels, that my "awake" time was unusually high even though the screen was always off (or so i thought), so i think the kernel was miscommunicating with my phone & keeping something up even when the screen was off. (not to bring display back into it, i swear )
    just saying that i think it was the kernel. & if slow-charge is the price i pay for good battery life, then i'll manage.
  25. #25
    Default
    So the problem is the ROM you flashed on your own device... makes sense... I would have said something about that, but you seemed I was guessing that if you flash a ROM you would read up on it and find out if there were any issues.
