Results 1 to 7 of 7
    Default Extended battery problems
    So we all know how horrible the Thunderbolt is on battery life. So I got the extended battery (the HTC on from verizon). I work a night shift 12 hours (and its a pretty slow pace) so needless to say I have allot of time to surf watch movies ect. The first 3 night I couldn't run the thing out started with a fresh charge at the beginning of the shift and with moderate to heavy use I could not run the battery out I even Bluetooth'd into the car stereo playing music the gps on running Google nav and the screen on with a 2 hour drive home I still had 34% battery left, AWESOME!!!!!!!!
    Now let's jump to tonight, the battery is dying faster then the stock regular battery. There are no rouge programs running. I'm doing my normal routine and the phone went down to 40% supper fast. So I restarted it on when it came back on it went from 40 to 19% .
    Sorry for being long winded but what causes this is this battery still breaking in? Is it bad? I'm not rooted so I can't clear the battery stats. Any helpful info would be appreciated
    Sent from my ADR6400L using Tapatalk
  2. #2
    willymakit's Avatar
    Posts
    Global Posts
    934 Global Posts
    ROM
    stock
    Default
    My battery life was also terrible yesterday also?
  3. #3
    Default
    Same here, but I also noticed 4g was flickering on and off when I was at work inside. Usually never turns off like it did.
  4. #4
    tcapote's Avatar
    Geek Freak
    Posts
    Default
    Are you in a 4g location? If so, there may have been issues, which can greatly reduce battery life. You could try using LTE OnOff (in the market) and turn off 4g and see how long your battery lasts on 3g.
    Sent from my Thunderbolt 4G LTE using Tapatalk
    There is no place like 127.0.0.1
    Default
    No I'm in a 3g area for work it was weird how bad it was last night. Today is great so far.
  6. #6
    willymakit's Avatar
    Posts
    Global Posts
    934 Global Posts
    ROM
    stock
    Default
    No 3G area only, battery life was perfect today, confusing.
  7. #7
    Drootz's Avatar
    Posts
    Global Posts
    158 Global Posts
    ROM
    GB & ICS
    Default
    Quote Originally Posted by Willymakit 75 View Post
    Strange seems like quite a few of us have had crazy battery life out of nowhere recently. I have been posting about my issues in this thread take a read see if there are any similaritites....
    http://forum.androidcentral.com/veri...ery-issue.html
