Results 1 to 3 of 3
    Default Help- Issue with Nova Launcher
    I have a gesture that when I flick up on my home screen, it toggles the notification bar. Yesterday, all of a sudden when I flick to hide, not only does the notification bar hide, but so does the wallpaper and the background turn signal black. When I flick again to bring the notification bar back, the background comes back. Any ideas? I have sent an email to nova support, but got an email they our out for a bit. Thanks
    Sent from my LG G2 using Tampatalk.
  2. #2
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Carrier
    CM 10.2
    Default Re: Help- Issue with Nova Launcher
    Are you able to disable the gesture altogether? You may want to delete it and then recreate it and see if that resolves the issue.
    Well i just turned it off. Left it like that for about an hour. Then recreated it and no luck.
  1. Replies: 8
    Last Post: 03-07-2014, 01:23 PM
  2. I have rooted Verizon S4 with VRUAME7 build, have safestrap, cant load Cyanogenmod... HELP!!!!
    By Eric Cetovick in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-11-2013, 08:31 PM
  3. Anyone have connectivity issues with the Note 2? Weak/bad signal.
    By hljeffries in forum Sprint Galaxy Note 2
    Last Post: 11-21-2013, 04:28 AM
  4. "Google Now" can't call phone numbers with local area code.
    By milomannn in forum Samsung Galaxy 3
    Last Post: 10-06-2013, 05:43 PM
  5. Question about my sd micro card with backup copy
    By Robert Burns4 in forum Site Feedback & Help
    Last Post: 10-03-2013, 10:44 PM
