Results 1 to 11 of 11
    Default battery life repost
    Ok i have a post of my battery problems a few posts below.
    I sent it to a verizon store to have it tested, and they said the battery was find. They put it through a 3 calling test, and when it came out, it was at 48 percent which they said it was normal. Its not. What should i do.
  2. #2
    Default Re: battery life repost
    Took my G2 off the charger yesterday early morning & it's still going. You have a lemon - sorry to say
    Sent from my Vzn LG G2 using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails battery life repost-1384923927106.jpg
  3. #3
    SuperMarioVT's Avatar
    Posts
    ROM
    Bugless Beast -Jelly Bean
    Yeap you have a bad device my phone easily go 2 days in a single charge with moderate use
  4. #4
    Posts
    ROM
  5. #5
    Quote Originally Posted by awesomedude118 View Post
    I don't know what a "3 calling test" is. Personally, I would still like to see the graphs. It is possible that this is some software problem that can be fixed.
  6. #6
    I use my G2 for personal + work (sync several emails & accounts) and still get over 2 days of usage. Best battery out there!
    FYI,
    iPhone typically lasted me 1 day.
    Samsung Galaxy aprx. 10 hours max.
  7. #7
    you guys with 24+ hours of battery life - have you rooted or disabled any stock software? i struggle to make it to 24 hrs on a charge - usually 20 hrs
  8. #8
    No I have not rooted yet. I did disable some unused (never used) apps like Amazon Kindle, Audible, Google Play Books & Magazines, etc. but I was getting 48+ hours regardless.
  9. #9
    Posts
    ROM
    Same here, unroot... Just disable Google now and turn down your brightness and your battery life will skyrocket
  10. #10
    joelvin's Avatar
    Posts
    Global Posts
    55 Global Posts
    I've disabled most of the bloat from LG (slide aside, smart screen, etc etc) and the Verizon Location Agent. This is a screen cap from last week but still! I have yet to try it, but someone else on the forums posted a Snapdragon Battery management app, not sure if that could help out. battery life repost-bzukzihimaamwzm.png
  11. #11
    My battery life is great on the G2!
    Sent from my VS980 4G using Tapatalk
  1. Battery stats reset after phone reboot
    By mzanette in forum Google Nexus 5
    Last Post: 03-10-2014, 04:30 PM
  2. Random Battery Drain?
    By holz75 in forum HTC One
    Last Post: 11-25-2013, 05:02 AM
  3. Sudden battery drain?
    By luqman24 in forum LG G2
    Last Post: 11-22-2013, 09:06 PM
  4. KitKat Breaks GSam Battery Monitor
    By jephanie in forum Moto X
    Last Post: 11-22-2013, 09:06 AM
  5. S4 Battery Question
    By ShadowBlazes in forum Samsung Galaxy S4
    Last Post: 11-20-2013, 09:41 AM
B
