02-20-2017 06:30 AM
27 12
tools
  1. dcolect's Avatar
    Worked fine earlier today, go to use phone and completely unresponsive. Plug it in, no charge, no lights, nothing.
    Happened once before, charged all night and still didn't work, brought it to the verizon store and before i could exchange it magically started working again.
    what gives?
    12-06-2013 01:44 PM
  2. Liliane Paradis's Avatar
    Mine just did the same thing last night! Had 37% battery left when I got home at 6pm, plugged it in, charged until it reached 100%, unplugged it. Went back to use it a while later....nothing. Not on, not turning on......so I plugged it back in overnight....still not working.....making a trip to Verizon today!
    12-07-2013 06:13 AM
  3. Kh F's Avatar
    Same thing happened to me this morning after charging to 100%. My husband looked it up a and did a soft reset by holding the power button for more than 5 seconds. Thathdid the trick and it has been working fine since.
    12-08-2013 09:09 PM
  4. cynthiakarel's Avatar
    LG G2 phone fully charged, will not tap on.
    help!
    04-08-2014 11:03 PM
  5. kstidhum's Avatar
    You are AWESOME! My phone has my life in it, so I definitely needed it to turn on as soon as possible (calender, contacts, etc.) I googled "LGG2 wont turn on" and this forum came up, sure enough I held the power button for more than 5 seconds closer to 8 seconds and IT TURNED ON! Weird how it even happened but thanks for sharing the advice!
    04-09-2014 11:40 AM
  6. KeepItReal's Avatar
    Please have a files backup plan in place. I recommend Verizon's Cloud. Search Playstore for VZ Cloud. Backs up contacts, messages (couple of month's, not all), music, pictures, video, call log, documents. You get your first 5 gigabytes free, but if your have Verizon's More Everything, you get 25GB free!
    04-13-2014 09:56 AM
  7. King Lemonite's Avatar
    OMFG!!! I looked at this website, and, ALAKASAM. It worked as if nothing happened by holding power button!
    04-14-2014 07:26 PM
  8. Oleg Milenin's Avatar
    To resolve power and charging issues, follow these steps:
    Plug your Nexus 5 into its original LG power adapter using the charger's original USB cable.
    Ensure the power cord is securely connected to the device and the power adapter. Also, make sure you're using a functioning power outlet.
    Wait for one minute, checking to see if a charging icon appears on the screen.
    Press and hold the Power button for at least 15 seconds to see if the device turns on. You will see the Google logo and feel a slight vibration.
    If this does not work, then press and hold the Power button for up to 60 seconds.
    Cannot turn on or charge: LG G2 | T-Mobile Support
    04-18-2014 09:26 AM
  9. spongedennis22's Avatar
    Ok after hours of figuring out what to do I did this as a last resort and it worked. I removed the screws from the phone and pulled the battery clip from the board ; then I pressed the power button , held it down and with the other hand clipped the battery back in, once the battery vibrated I put the phone on the charger and it turned on showed the lg logo and then showed that the battery was at 0% but was charging. My phone was not rooted it was just sitting on my desk for a week till I got back from vacation. I hope this Helps
    07-15-2014 09:31 AM
  10. Mohsin Ali4's Avatar
    Hi everyone i hope you all doing good. How i figured out about my LG G3 when suddenly i found it not charging at all
    even i left it on charging all night.
    Follow the steps and you'll be able to bring it back on normal charging.
    1. Keeping the battery inside, press the power button until your screen stops blinking and stops showing 0% with charing logo.
    2. Don't plug the charger unitl you see no blinking screen, it actually drains out the reserve that stops it from
    charging in normal way.
    3. Once you complete the 1 & 2 steps, plug it to your LG charger and it'll start charinging normally.
    Hope it works for LG G2 users as well.
    03-25-2015 12:37 AM
  11. Shelly Monahan's Avatar
    Thank you so much!!!!!! I love you!!!
    06-10-2015 06:17 AM
  12. RIRIBBHMM's Avatar
    It really works! Thank you! Just hold power bottom 8-10 seconds and it turns on!
    07-06-2015 01:17 PM
  13. laurawesley's Avatar
    LG EXCEED2 smart phone won't turn on after a full charge....help!
    07-26-2015 11:08 AM
  14. Daisy Sucuzhanay's Avatar
    i just got my new lg g2 and when i got it i connect it to the charger then turn it on and it still 0%. and it said do not unplug and i didn't. i need help in what to do
    08-28-2015 01:39 PM
  15. kenzierdolan1027's Avatar
    Awesome! i was trying everything to get my lg g2 to turn on and wallah!
    12-18-2015 02:36 AM
  16. Amanda W1's Avatar
    You rock... it worked... but I had to do it for 10 seconds... saved me a trip to Sprint store the datacenter Christmas! Thank you!
    12-24-2015 02:25 PM
  17. Simon Oxley's Avatar
    Thank you! I held for the full 60 seconds and it sparked back into life. Thought it was a goner. Cheers
    03-14-2016 04:13 AM
  18. siipimutu's Avatar
    Well, i had same problem and followed all instruction here, nope.... Dead and dead. Anyways, i tried something different since i have no warranty on phone. I opened back panel and then dismantled upper panel of phone inside so i can see motherboard, disconnected battery from motherboard (i didn't remove it from phone case) then i just simply put my phone to freezer. I let it be there for 1 hour. After that i connected battery to mobo and put charger. Phone screen turned on showing battery logo and temperature warning. Then i removed charger and battery and let it heat up with room temperature. Now it works fine, not sure for how long tho.
    Warning: Might not work and might break phone even more.
    05-01-2016 10:16 PM
  19. Ignacio Imendia's Avatar
    Sir you are a genious, THANK YOU SO MUCH!
    06-01-2016 06:27 PM
  20. Angel Saenz1's Avatar
    what gives?
    I opened the back up nd took out the battery for like a mi.ute and then put the battery back in and held the power button and it turned on then i plugged it in to charge
    08-19-2016 10:49 PM
  21. William Okonji's Avatar
    What i did was to take out the screws, pulled out a few clips connecting to the panel, hold down the power button without the battery in it for 60 secs, connect back the clips, connected a usb from my computer to the charging port and voila it came on, but i noticed the sim card region kept getting hot.
    09-27-2016 04:41 AM
  22. Furqan TT's Avatar
    i had 40% of battery in lg g2. i left it at home. i came back and it didnt turn on and when i put the micro usb on to charge to symbol comes its a blackout. plzz help me out.
    01-03-2017 09:29 AM
  23. Furqan TT's Avatar
    simon did it had battery when it turned off ?????
    01-03-2017 09:45 AM
  24. Niknik83's Avatar
    Turning the phone off, taking the battery out and setting it aside for awhile (I tried 10-20 minutes) worked for me too with my Lg G Vista (VS880). When I placed it back in and attempted to turn it on, it came back on like normal. Thank you Jesus Money and time saved thank you to all the people who post tips to help, you're appreciated Have a blessed day everybody
    01-05-2017 11:48 PM
  25. Niknik83's Avatar
    Hello! Just saw your post and literally just experienced a blackout about an hour ago taking battery out for about 20 minutes and putting back in and then trying to turn on worked for me. Hope this helps! Have a blessed day!
    01-05-2017 11:52 PM
27 12
  1. Good phone, but I like the HTC G2 better
    By zencoder in forum T-Mobile Galaxy S 4G
    Last Post: 06-10-2011, 09:22 AM
  2. HELP! A friend rooted my Evo 4G today and it won't go past intro/turn-on screen!
    By shtaylor1 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 05-17-2011, 01:34 PM
  3. Gallery won't open
    By Lurch81#AC in forum Motorola Droid X
    Last Post: 05-16-2011, 09:23 AM
  4. View sd card on LG Optimus V
    By jmk909er in forum Virgin Mobile Optimus V
    Last Post: 05-15-2011, 10:24 PM
  5. lg mobile support tool help
    By chrismartinez0 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 05-15-2011, 10:00 PM
