Results 1 to 4 of 4
    alcor34's Avatar
    Posts
    Global Posts
    324 Global Posts
    Default Back/Battery Door Replacement
    I have been looking for a replacement back for my LGVS980 all over the net, but to no luck. Some websites say that they have it but then they show a picture of the ATT version. I don't want to have the hassle of ordering and waiting only to find out that they have sent the wrong one.
    Does anyone on here know where I can buy the back cover specifically for the Verizon G2.
    Many thanks, much appreciated.
  2. #2
    SuperMarioVT's Avatar
    Posts
    ROM
    Bugless Beast -Jelly Bean
    Default Re: Back/Battery Door Replacement
    I didn't think you could remove the back from the Verizon version... You might have to contact LG directly
    alcor34's Avatar
    Posts
    Global Posts
    324 Global Posts
    I have already removed the back door, with the edge of my clipped fingernails at that. It's actually really easy to do (don't advise anyone to do it) It snaps back on like a samsung back. I ask because i noticed that the mesh covering my speaker was loose, so i took the back off, and of course it was in fact falling off. This phone attracts a lot of lint and I'm not sure what will happen when the space begins filling. That's why I'm looking for a new back that has the mesh already glued in.
  4. #4
    dgcamero's Avatar
    Posts
    Global Posts
    97 Global Posts
    Quote Originally Posted by alcor34 View Post
    I did not realize that you could change the back of the phone, so I called LG and asked where I could purchase a white back to replace my black back. They said that since it's not removable (it really is like a Samsung or HTC back, but harder to remove), that I would have to send it to them to replace the back.
  1. Anyone Else Getting Bad Battery after MJ7 update?
    By stanley08 in forum Samsung Galaxy Note 3
    Last Post: 12-28-2013, 11:28 AM
  2. Massive battery drain, even when charging, only in Mexico
    By dcdtrax in forum AT&T Galaxy Note
    Last Post: 12-23-2013, 01:37 PM
  3. Looking for a replacement for WinAmp
    By VegemiteKid in forum Entertainment
    Last Post: 12-15-2013, 10:28 PM
  4. Ok, seriously, my nexus 7 runs out of battery fast
    By wuzao14 in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-14-2013, 12:42 PM
  5. Replies: 17
    Last Post: 12-14-2013, 08:37 AM
B
