My wife's G2 started to blackout th screen when a call is made and removing the phone from your ear does not turn it back on. It has the quick window cse and if you open and close the small windows allows you to end the call. Any solution?
Try not to cover the proximity sensor.My wife's G2 started to blackout th screen when a call is made and removing the phone from your ear does not turn it back on. It has the quick window cse and if you open and close the small windows allows you to end the call. Any solution?
The note 3 has these issues as well. I wonder if it is a bug. I got a replacement and it is fine now, but I don't know. That is highly annoying. If it happens again I will ask for a different phone.
Sent from my SM-N900V using Tapatalk
