Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By bosscib
    Default Difference between Global and LTE/CDMA?
    Does anyone know the difference between these two?
    this setting is under Mobile networks -> system select
    By default mine was set to Global. I changed it to LTE/CDMA, but should I have left it on global? Which gives better connection? Which does better 4G to 3G switching?
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    2,693 Global Posts
    ROM
    CodefireX One XL 4.4.2
    Default Re: Difference between Global and LTE/CDMA?
    Quote Originally Posted by denarok View Post
    If you are in the U.S I recommend sticking with LTE/CDMA.
    If you travel alot to different countries, I recommend staying with Global.
    It is our choices, that show what we truly are, far more than our abilities. - J. K Rowling
    "If you love life, don't waste time, for time is what life is made up of." - Bruce Lee
    "The story of life is quicker then the blink of an eye, the story of love is hello, goodbye." - Jimi Hendrix
    Quote Originally Posted by wizzrah View Post
    I have never been outside the US my entire life, and doubt I will travel much never know so I guess will leave it on LTE/CDMA
    by the way has anyone figured out a way to force it to use 3G only? This way if you travelling in a fringe area and know it will switch a lot I bet will save battery then trying to find a signal? I use to do that with my old gnexus.
    The other G2 variants have that option right there under mobile settings but for some reason verizon will not give you that option, not sure why.
    Thanks
  4. #4
    I'm in Ohio and on Verizon. For some reason, MMS sends faster when I have it set to global instead of cdma. Not sure why, but it does.
  5. #5
    wizzrah's Avatar
    Posts
    Global Posts
    2,693 Global Posts
    ROM
    Quote Originally Posted by JJ Jones View Post
    Either one works fine, global is better if you roam a lot.
  6. #6
    dgcamero's Avatar
    Posts
    Global Posts
    97 Global Posts
    Thanks
    No need with the Snapdragon 800...
    Quote Originally Posted by dgcamero View Post
    oh really? I had no idea the CPU made a huge difference in terms of 3g/4g switching? I guess I will find out this week when I do some travelling.
  8. #8
    wizzrah's Avatar
    Posts
    Global Posts
    2,693 Global Posts
    ROM
    The phone will automatically detect when 3g and 4g is available. By design I believe 4g will be automatically picked over 3g.
  9. #9
    Seems like when my phone loses 4G it is hard to find back. If I reboot it will usually find it again.
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by niekamdt View Post
    That did happen to me today, what I did instead of rebooting was switch from LTE/CDMA, to GLOBAL, then back to LTE/CDMA and found 4G, I guess that resets radio instead of rebooting
  11. #11
    global is for other countries and for the united states GSM carriers like if you put a At&t sim or Straight Talk sim in the phone after setting up your APN settings you will have voice text and data via HSPA+(4g) or a t-mobile sim you will have voice text and data via their EDGE (2g) network unless your in a reframed 4g area of t-mobile then you will also have HSPA+ also if you want to lock your phone to 3g only you can use this app open the app scroll to the bottom click additional info then phone information then scroll to the middle of the page and in the drop down box click on CDMA auto (PRL) you can also lock it to lte only by clicking lte only but you cant make or receive calls only send and receive texts hope this helps
  12. #12
    dookie.'s Avatar
    Posts
    Global Posts
    200 Global Posts
    Quote Originally Posted by brian7751 View Post
    global is for other countries and for the united states GSM carriers...
    'Global' was the default on my domestic, Verizon-issued (and SIMed) G2. As I read the OP, this appears to be the case on all of them. Given your statement, why? Oversight?
  13. #13
    im trying to be as helpful as possible
  14. #14
    bosscib's Avatar
    Posts
    Global Posts
    123 Global Posts
    I've tried multiple apps that are supposed to allow you to switch to CDMA (3G) only, but none of them work with the Verizon G2. With this app you referenced, clicking on Phone Information generates a Note "This application does not work on this device."
    Tyler510 likes this.
  15. #15
    ok i wasnt sure i dont have the g2 but i had the note 3 and i have the droid maxx and it worked on both of the phones so i only guessed that it would also work with the g2 im sorry if the app wasnt compatible its a great app i heard that the g2 has a hidden menu you can get to via the dial pad but im not sure if there is a way to get it to lock to 3g from it.
  16. #16
    bosscib's Avatar
    Posts
    Global Posts
    123 Global Posts
    No worries thanks for the suggestion. I don't believe the hidden menu has the 3G option available either. I have a Verizon network extender and typically only get 1 bar of 4G, so locking on 3G always worked with my S3. Haven't been able to do this with the G2 yet so I disconnected the network extender.
    Thanked by:
  17. #17
    ok sorry i wasnt able to help though hopefully someone will be able to find out something or maybe the app will get updated to where it will work on the g2.
    Thanked by:
  18. #18
    What if I want to use 3G or 1X for less battery consumption? Or is the difference between 1X, 3G and 4G negligible?
  19. #19
    wizzrah's Avatar
    Posts
    Global Posts
    2,693 Global Posts
    ROM
    Quote Originally Posted by Tyler510 View Post
    No difference in battery life.
    Sent from my HTC One X using Tapatalk
    Thanked by:
  1. I imported my pictures from my computer and can't find them.
    By marcge in forum Motorola Droid MAXX
    Last Post: 02-27-2014, 11:14 PM
  2. S3 4.3 and FoxFi
    By Rithisak in forum Verizon Galaxy S3
    Last Post: 01-11-2014, 03:00 AM
  3. Widget and Function Question
    By nochlux in forum Android Graveyard
    Last Post: 12-29-2013, 12:32 PM
  4. Replies: 4
    Last Post: 12-28-2013, 11:22 AM
  5. Besk backup app/pc program for apps and apks
    By oldbreeches in forum ASUS MeMO Pad HD7
    Last Post: 12-28-2013, 09:05 AM
B
