1. Seiryu769's Avatar
    So I have had my LG G2 for a month now. I really should take it in, but have been pretty busy.
    However when I am using the text messaging, when I type something it will add random periods in between words. I have tried googling to see if anyone else has had this issue with no luck. For instance, an example ;
    What it SHOULD look like ; "I went to the store after work."
    What mine will sometimes do (often) ; "I.went to.the.store after.work."
    And no, I am not hitting the "." key. I can be very careful and see the space bar light up as I hit it, and still shows a period.
    I have also noticed annoying loud noises when on the phone with someone, kind of like someone is hitting a button on their phone, but isn't. Another issue I have is the voice-mail quality. 90% of the voice-mails make the person sound like a grainy robot. Phone calls are fine quality wise, voice-mails not.
    Any help on these issues and if they are fixable would be great. Or what I should ask Sprint to do while they fix my phone. Thanks!
    01-17-2014 06:14 PM
  2. Golfdriver97's Avatar
    I would check 2 things. In settings, is there an option for tapping the space bar twice to add a period, or anything like that?
    The other thing I would do is go to Settings>Apps>Keyboard (whatever it may be called, possibly LG Keyboard)>clear cache.
    01-19-2014 11:05 AM
  1. Back and menu button bypass?
    By kach474 in forum Samsung Galaxy S4
    Last Post: 03-05-2015, 12:39 AM
  2. Right to Work and Unions
    By NoYankees44 in forum Politics
    Last Post: 12-12-2014, 08:04 AM
  3. Replies: 18
    Last Post: 01-28-2014, 01:34 AM
  4. How to relock the boot loader and unroot the galaxy nexus.
    By Ridgerunner20 in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 01-21-2014, 05:25 AM
  5. G-Box and Xbmc
    By Anon8154066 in forum General News & Discussion
    Last Post: 01-17-2014, 04:31 PM
