Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By lingcod777
    stellaxtine's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default LG G2: Nonstop LED flashing
    So I woke up this morning to my LED notification light flashing every color. After clearing the notifications that had accrued over the night and checking my settings, it still doesn't stop. It never did this before and I'm not sure why it's suddenly doing this now. When I have an actual notification, like a text or email, it'll only flash green- like it normally does- but when there aren't any notifications, it just continually flashes rainbows at me. Is this a new thing? I don't want to turn off that light permanently, because I like when it's actually doing its job of notifying me, but now it's just annoying How do I fix this?
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nonstop LED flashing
    Quote Originally Posted by stellaxtine View Post
    have you been using some application that makes your LED flash, if yes then uninstall that and try installing a different application that suits your need.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kelly Burby View Post
    No, I haven't downloaded any new apps recently
  4. #4
    Ed_Grohl's Avatar
    Posts
    Global Posts
    96 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Using Light Flow?
    If so you actually have to go into the app to get the light to stop. Swiping the notification away does not do it.
  5. #5
    TNCattleDog's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    try rebooting your phone.
    David
  6. #6
    NickA's Avatar
    Posts
    Global Posts
    2,672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: LG G2: Nonstop LED flashing
    Mine did the same exact thing a week or two ago. It was when I woke up like you, and went to unplug it. I cleared notifications and it still flashed. Mine was flashing three different colors. Rebooted and haven't had the issue since.
    No special apps or anything like that wants to do anything to the LED installed.
  7. #7
    lingcod777's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had this, or something similar, happen twice when my morning alarm (stock alarm) when off. I hit snooze but it never alarmed again and the LED was flashing through it's range of colors. No new apps other then updates. I haven't had a chance to dig into/repeat it yet.
    Alexandgut likes this.
  8. #8
    JJ Jones's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Settings, display, tap notification light. Sounds like the led is set to display when the alarm goes off.
  9. #9
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    then, i guess enjoy the different colors !! i don't think it is annoying in fact its wonderful.......
  10. #10
    MexeM's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had this problem too... The back button led was blinking also.
    Rebooting only solved temporarily, since the next morning the phone was again blinking as a Christmas tree.
    I figured out the problem was with the alarm/clock app (the front led is set to rainbow blinking on alarms, as is the back led), so I tried deleting the application cache and data and now it seems working again as it should...
  11. #11
    sherrylou937's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My phone did the same thing and it was driving me crazy. I removed the SIM card and reinstalled and have had no problems. This did happen after I used the USB cord to download photos to my laptop. Not sure if this was the cause or not.
  12. #12
    shadowsjc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    same thing happened to me. a reboot solved the problem. haven't been able to recreate the issue on command, although it has happened 3-4x over the past couple of months. i do not use a third party alarm app (i only use the built in alarm app)
  13. #13
    Lisa Claber's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had this phone set up yesterday and set my alarm for this morning. The green flashing light is definitely the alarm. I've just turned it off and the light has gone.
  14. #14
    Ace Of Grenades's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i found a solution the will solve the problem permanently
    1.go into your alarm clock and set a new alarm 1min from now
    2.when it rings tap dismiss and done your rainbow led should be gone.
  15. #15
    tiffersxP's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Ace Of Grenades View Post
    Oml Thank you! Finally something that works. I tried everything else on mine and it wouldn't stop, but right after I did that, the problem was resolved.
  16. #16
    Barb Goss's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My phone was blinking a green light...I couldn't figure it out. I pulled the menu down and there I saw that I had deleted 31 contacts (I only want phone contacts not facebook or google) and it wanted me to verify. I did and the light went out. Usually a blinking light of any color means it wants some type of action from you.
  17. #17
    Tony Hammond's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I have to do this every day to get this to stop???
  18. #18
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I have to do this every day???
  1. Flash player on LG G Pad
    By dorblayzer in forum LG G Pad 8.3
    Last Post: 08-26-2014, 07:13 PM
  2. LED Notification Light
    By gl12ox05 in forum Droid RAZR MAXX HD
    Last Post: 01-31-2014, 06:11 PM
  3. Flashed a Custom Rom to my device, but can't access my internal sd card.
    By PixelArt56 in forum General Help and How To
    Last Post: 01-25-2014, 09:53 AM
  4. Pictures with flash enabled are darker
    By pappy53 in forum Motorola Droid MAXX
    Last Post: 01-24-2014, 06:44 PM
  5. Flashed A Nightly and My Phone Died of Heat!
    By Luis Jimenez5 in forum HTC One M7
    Last Post: 01-24-2014, 06:00 PM
