Results 1 to 3 of 3
    rvgraham's Avatar
    Posts
    Global Posts
    240 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Will it come back? (Water damage)
    So my wife asked me to look at the dishwasher that was misbehaving. I open it and see an inch + of soapy water that failed to drain. I lean over to look inside and my G2 slips out of my jacket pocket right into the water
    After doing all the wrong things (trying to power it back up, stick it in a bag of rice overnight) I wake up the next morning and my brain is working normal again. Go to iFixit and find out how to dismantle it.
    I dried off all the parts after dismantling it down to removing the circuit boards, everything except the battery. Left everything to dry until I come home from work ten hours later. I re-assemble the phone and power it back up.
    Seems to work OK, except:
    • The notification led is on continuously, red
    • The drop down notification panel only works in landscape
    • The keyboard (Swype or stock LG) loses my trace partway through words
    So, opinions, history??? I've had phones slowly come back to normal after a few days or weeks of regular use. Just not sure if that is likely with this phone and these kinds of symptoms.
    Thanks, and may this not happen to you!
  2. #2
    scottysize's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Will it come back? (Water damage)
    That's why I pay for the insurance. I know it sucks to pay each month, but I get my phone replaced for $50 as long as I can turn in the parts. I hate to say it, but it sounds toast to me.
  3. #3
    murdalok's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Honestly try a Factory reset to see if it straightens out any issues. Otherwise use insurance if you have it.
  1. Got It - Samsung Galaxy Note 10.1 (2014)
    By calvindm3 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-02-2014, 05:42 PM
  2. flex in case-back normal?
    By aweber1nj in forum Moto X (2013)
    Last Post: 02-28-2014, 01:21 PM
  3. Unlocked Vzw Motox Developer Ed, will I lose root? 4.4.2
    By ShawnMeds23 in forum Moto X (2013)
    Last Post: 02-28-2014, 12:10 PM
  4. LG G2 Creates its own alarms!
    By nickyjoe99 in forum Verizon LG G2
    Last Post: 02-28-2014, 09:30 AM
  5. Is there a way to disable back to top function when returning to previous menus?
    By Droidboner in forum Android 4.0 Ice Cream Sandwich
    Last Post: 02-28-2014, 08:48 AM
