1. shadowsjc's Avatar
    Stock LG G2 (launch day), unrooted
    As of yesterday, whenever I make a call and hold the phone up to my ear, speakerphone automatically turns itself on. If I hit the speaker button to turn it off, and then re-place to my ear, it turns back on again. I'm pretty positive I am not making contact with cheek and accidentally turning it on. Super weird. Any ideas? Thanks!
    03-01-2014 04:09 PM
  2. murdalok's Avatar
    Try rebooting the phone. Also try safe mode. Just hold the power button until it gives you the option to power off, then press and hold power off. A prompt will appear asking you to boot into safe mode.
    If it works fine in safe mode, that indicates 3rd party software is causing the issue.
    Besides that i recommend a factory reset. If none of that helps, Since your within youre 14 days of purchase i would return the phone ;-).
    Of course you could always contact Verizon, we are always happy to help.
    0331 likes this.
    03-03-2014 10:45 AM
  3. farmjope's Avatar
    Same thing just started happening with my Optimus G. Something is going on with LG phones. There's another thread about it and it just started happen to both my phones a few days ago.
    03-03-2014 05:52 PM
  4. Hunan's Avatar
    My G2 started to have all calls, received or outgoing start with speakerphone on. This stopped after I restarted the phone.
    03-04-2014 02:12 PM
  5. shadowsjc's Avatar
    i folded up a small piece of paper and cleaned out the USB port on my phone. There was some lint and junk in there - nothing too major.
    I also rebooted in safe mode and did not experience the problem.
    Now I've been running it normally for a day and I haven't seen the problem again. I am hoping that it was just gunk that was interfering with the USB port and made the phone think it was docked. (I read that this may happen to other android phones).
    03-04-2014 02:42 PM
  1. Android Phone buying guide in reasonable budget
    By Kashan Osama in forum Moto G (2013)
    Last Post: 03-04-2014, 06:49 PM
  2. Replies: 1
    Last Post: 03-02-2014, 04:26 PM
  3. how to add a new phone contact without corporate sync...
    By goodseed in forum General Help and How To
    Last Post: 03-01-2014, 07:58 PM
  4. Replies: 1
    Last Post: 03-01-2014, 06:18 PM
  5. Games not working and missing on sd card. Help!!
    By executiveg in forum Samsung Galaxy Note 2
