Results 1 to 4 of 4
    Default LG G2: Constant Battery Drain?!
    So I use my phone lightly and when it is on standby for not even 5 minutes, I unlock it to see it drains down 1% each time I turn on the screen. It's drained around 20% in the last hour and I only used it 4 times so it seems to be getting way worse. It wasn't like this when I first got it. Any solutions?
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Constant Battery Drain?!
    Could you post screenshots of your battery stats, please?
    Sent from my Galaxy S4 running SlimKat 4.4.2
  3. #3
    Check location access. It's a battery hog if your phone can't find satellites.
  4. #4
    Charge the Battery to 100%... While still plugged in.. Do a SOFT Reset.. This will reset the phone, without losing anything, and re tell the battery where the 100% mark is on the battery.. its not the battery actually dieing faster, its just the indicator is screwed up... unfortunately, even though the phone isn't actually dead... the phone is programmed to do the normal things at "Low Battery" and eventually turn itself off at 0%,
  1. Nexus 5: What ROM for Battery, Speed, and Stablity?
    By shawn.selig29 in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 09-09-2014, 08:29 PM
  2. ZeroLemon 7500mAh battery not being recognized/charging
    By Corey Copp in forum Samsung Galaxy S4 Accessories
    Last Post: 04-05-2014, 05:26 AM
  3. Note 3: The battery life is the best I have seen from my experience
    By Closingracer in forum Samsung Galaxy Note 3
    Last Post: 03-31-2014, 02:09 PM
  4. ZeroLemon 7500mAh battery not being recognized/charging
    By Corey Copp in forum Chargers and Batteries
    Last Post: 03-29-2014, 01:25 PM
