Results 1 to 6 of 6
    Default Battery life - HELP!
    I've been biding my time with my phone. I used to get ~20-22 hrs life on a charge - not quite the 2-3 days some people post about, but it was ok for my purposes. Lately though my battery life has plummeted. I'd really rather not factory reset, although it is looking more and more likely that will be the case. I am on a stock launch day LG G2 (never before rooted). Here are some screenshots:
    Edit - also halfway during the day, the phone was in airplane mode for 1 hr, so nothing should have theoretically been transmitting during this period.
    Anecdotally, whenever I browse the web on my phone, the back becomes very warm or hot. Not sure why this is.
    Brightness is set to autobrightness (55% baseline). GPS/bluetooth/wifi off unless I am using it (have not used it once today).
    Any tips? Thanks!
  2. #2
    joelvin's Avatar
    Posts
    Global Posts
    71 Global Posts
    Default Re: Battery life - HELP!
    I'm also having this issue with my VZW G2... I'm not sure if you have the app FolderSync but I uninstalled it and it seems like the phone is draining slower but still at an abnormal rate. Hopefully someone has better ideas :-(
    Sent from my VS980 4G using AC Forums mobile app
  3. #3
    Ultimately, you will have to do the factory reset to see if it's the Phone. Download VZ Cloud from Playstore (or update existing app) and run over WiFi to backup everything. Then, backup anything else additional you need (check out what the cloud backs up...it's a lot! ). But....I would wait for the latest Kit-Kat update to install...Then do the factory reset. I usually do factory resets after each major software update...I like to think it clears up any garbage from my prior use.
    Yeah I was hoping to wait till kit Kat before factory resetting. Going on vacation next weekend so I might have to reset either way before then
    Sent from my Verizon LG G2
  5. #5
    FDR sounds like your best shot. If it was me, I'd turn off the data backup, then be careful about what goes back on it.
    I was having battery issues, but it was because I had location access turned on and it couldn't find the satellites. After turning it off, my phone is where i think it should be on battery life.
  6. #6
    I am noticing GPS and/or Location services not locking in on the actual location. I see 'Finding Location' in my notification screen, infrequently, which means the Phone is searching, searching searching....and probably draining battery right along with it! Other threads discuss GPS not functioning correctly. Hopefully fix is in the next update!
  1. Replies: 8
    Last Post: 04-07-2014, 04:22 PM
  2. Please Help... My Motorola turns on and turns back off!!
    By aziwolf in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-06-2014, 10:12 AM
  3. Replies: 6
    Last Post: 04-04-2014, 09:10 PM
  4. Help please...how to change photo location
    By Andrew Rhodes1 in forum HTC One M7
    Last Post: 04-04-2014, 02:55 PM
  5. Help
    By Lynn Myers in forum Samsung Galaxy S3
    Last Post: 04-04-2014, 12:37 PM
