1. TheBull50's Avatar
    So im running TWRP 2.6.3.3 . I was installing a rom when I wiped out the internal storage. Therefore, wiping out all the roms. What can I do now? Can I somehow get the phone into usb mode and reload the files?
    04-15-2014 03:42 PM
  2. SactoKingsFan's Avatar
    You wiped everything on the phone including the OS? Or did you just wipe internal storage?
    Sent from my G2 running PAC-ROM
    04-15-2014 09:28 PM
  3. TheBull50's Avatar
    I def know I deleted internal storage. I am trying to use the LG Tools now to at least try to have an OS running. I have about 20 minutes left before its done . Hopefully it woks.
    04-15-2014 09:36 PM
  4. SactoKingsFan's Avatar
    LG flash tool should only take a few minutes to install software.
    04-15-2014 09:46 PM
  5. TheBull50's Avatar
    I am doing this for a VZ phone. Im in firmware update but it doesnt seem like anything is happening. LG is getting the software it seems but then once it downloads, the programs gives me an error and quits
    04-15-2014 10:08 PM
  6. TheBull50's Avatar
    so i could have very well deleted everything. like i said, internal storage for sure
    04-15-2014 10:14 PM
  7. SactoKingsFan's Avatar
    Try this method. Should work if you use the Verizon firmware file.
    http://forum.xda-developers.com/show....php?t=2432476
    04-15-2014 10:18 PM
  8. TheBull50's Avatar
    when I get to the step of reading my phone info, it wont find a port number or any of my phone info
    04-15-2014 10:23 PM
  9. TheBull50's Avatar
    and on my phone, no movement on the progress bar
    04-15-2014 10:30 PM
  10. SactoKingsFan's Avatar
    Do you have the correct drivers installed and have you unlocked LG flash tool?
    04-15-2014 10:49 PM
  11. TheBull50's Avatar
    how do I unlocked LG flash tool? it keeps asking me for a user name and a password at the login screen
    04-15-2014 11:02 PM
  12. TheBull50's Avatar
    keeps telling me Wrong .DLL file. I followed the web page exact too :-/
    04-15-2014 11:12 PM
  13. TheBull50's Avatar
    i was using the megalock.dll but found this file in the KDZ method folder LGVS980_20130902.dll
    is that the one
    04-15-2014 11:17 PM
  14. TheBull50's Avatar
    i can get into twrp though.
    04-15-2014 11:51 PM
  15. SactoKingsFan's Avatar
    The megalock.dll file is used to unlock LG flash tool. Once it's unlocked it will recognize your G2 and display phone info.
    You also need to download the LGVS980_20130902_LGFLASHv151.dll and VS98010B_13.tot files. Then change port in device manager to COM 41. Choose DLL file and tot file in flash tool. Software install should start when you press yellow arrow.
    04-16-2014 12:11 AM
  16. TheBull50's Avatar
    I have all of that and I am able to select it all. Once I try to install, it doesn't work. Tells me Failed Previous Load().
    I can reboot and still get into TWRP through
    04-16-2014 12:29 AM
  17. anthony young2's Avatar
    Hey man, Did you ever find a solution for the (failed previous load) in LG flashtool?
    I've been soft bricked and its the only thing keeping me from un-bricking my phone. It would be greatly appreciated to hear back with your answer.
    07-22-2014 10:25 AM
  18. anthony young2's Avatar
    07-22-2014 10:28 AM
  19. TheBull50's Avatar
    I did fix it. I basically taught myself how to use ADB Push. Here is the link I was using:
    [HOW-TO] ADB Push a ROM to your phone | HTC One S | XDA Forum
    find a good factory rom to push as well. Again XDA is the spot to look
    07-22-2014 11:48 AM
  1. HRM can't find the sweet spot on my wrist.
    By AldousSnow in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-21-2014, 09:39 AM
  2. Newbie help please?
    By fitcherama in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-15-2014, 06:54 PM
  3. Samsung G S III sprint sph-l710 Help & question's
    By babyboy3703 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 04-15-2014, 04:56 PM
  4. Nexus 7 wont turn on, and wont show up on my computer HELP!
    By Jack Belmore in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-15-2014, 01:23 PM
