1. Romie Lee's Avatar
    Cant get them to slide up to use them
    04-25-2014 09:59 AM
  2. Udis's Avatar
    I have a similar issue, I can get the keys to pull up but the damn swipe up Voicemate/search/quick memo thing keeps popping up too, and I forget how I disabled it last time on 4.2.2
    04-25-2014 10:29 PM
  3. Romie Lee's Avatar
    Mine is not working at all but when I flip it to landscape it works fine. One of the main reasons I rooted...sucks.
    04-27-2014 04:00 AM
  4. jeff327's Avatar
    You can use the immersive mode app. It works with kit kat and root is not needed.
    https://play.google.com/store/apps/d....immersivemode
    Udis likes this.
    04-27-2014 07:49 AM
  5. physioprof's Avatar
    Could it be that you Animator Duration Scale set to off in Developer Options? This caused a new problem on KitKat with status bar knock-off. Maybe try setting it to a non-zero value.
    Sent from my Nexus 7 using AC Forums mobile app
    04-27-2014 08:32 AM
  6. Udis's Avatar
    -jeff327 Does excatly what I'm looking for, thank you!
    Actually it doesn't let me click any options when going into menus/settings etc time to remove
    04-28-2014 03:13 PM
  7. Tex_Norseman's Avatar
    Try Gravity Box module for Xposed. Full Immersive mode, works as good if not better than GMD Auto Hide.
    05-21-2014 07:36 PM
  1. After update to android 4.4.2 kitkat wifi stop find networks sgh-m919
    By sergioaleagas in forum T-Mobile Samsung Galaxy S4
    Last Post: 08-21-2014, 02:46 PM
  2. Note 10.1 How are you using it to Work?
    By Unclejoe36 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-02-2014, 02:04 PM
  3. Any ETA on the Wireless Samsung S Charger Kit for the Galaxy S5?
    By felloffthetruck in forum Samsung Galaxy S5
    Last Post: 05-12-2014, 08:09 PM
  4. The theory behind 'rooting'--
    By megabyzus in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 04-25-2014, 07:33 PM
  5. Replies: 0
    Last Post: 04-25-2014, 09:53 AM
