1. Bonyboy's Avatar
    I'm guessing this is a common issue w/ those who have upgraded. I have a white G2 on VZW and since the upgrade I am constantly having trouble playing anything audio in any programs. Podcasts, music, or audiobooks all will stop at random times. This happens when streaming content or playing downloaded content. Has anyone found any crazy key combination to get this fixed since there has been no update?
    05-06-2014 01:47 PM
  2. JJCook's Avatar
    I'm having the same problem.
    05-06-2014 08:46 PM
  3. acejavelin's Avatar
    In just Play Music, or in ANY streaming app? I use my G2 to stream from Pandora, Spotify, and XM Sirius all the time and it never pauses or skips... I have very little internal music loaded, but I usually use WinAMP or Fusion player and have no issues. The only thing I use the stock player for is voicemail WAV file attachments in emails.
    Play Music does have a known issue where it will pause at times when streaming, most people have it, but I have heard little issues with other media or players.
    05-07-2014 12:16 AM
  4. Bonyboy's Avatar
    I have tried it with different apps. Pocketcast, Plex, Hearts of Space and they all have the same issue.
    05-07-2014 01:14 PM
  5. acejavelin's Avatar
    Odd... Have you tried a factory default after getting the upgrade? It is HIGHLY recommended if you have any issues since although on the surface it looks very similar, the underlying changes are quite extensive.
    05-07-2014 04:56 PM
  6. Bonyboy's Avatar
    What do you mean by factory default?
    05-08-2014 12:01 AM
  7. somnambulator's Avatar
    I'd do a factory reset.
    I upgraded to stock kitkat and had terrible idle battery drain and a reset fixed it. now the phone is better than when on jellybean, where it was my all time favorite phone.
    I use pocketcasts, poweramp, tune in pro, and Spotify daily and haven't had any issues since update.
    Sent from Tapatalk using my xposed VZW G2
    05-08-2014 07:16 AM
  8. acejavelin's Avatar
    A hard reset... Wipe all info and return it to out of box condition.
    http://m-support.verizonwireless.com...7344.tp_2.html
    Sent from my Nexus 4 using Tapatalk
    05-08-2014 09:28 AM
  9. JJCook's Avatar
    I'm having the same problem. Did a FDR to no avail. The problem still exists.
    05-08-2014 09:47 PM
  10. Bonyboy's Avatar
    Yep, I did as well.I think our has happened twice since FDR.
    05-09-2014 10:00 PM
  11. JJCook's Avatar
    Does anyone have any thoughts on this? It is getting old really fast!
    06-22-2014 08:14 PM
  12. JJCook's Avatar
    I think I've resolved my issue with a FDR. Knock on wood, so far, so good. I didn't want to do it, but the pausing was driving me nuts!
    JJ
    07-19-2014 06:43 PM
  13. JJCook's Avatar
    No joy on this issue. There is no consistent set of circumstances that cause this to happen. Very frustrating when your hands are wet and the music just stops. Any thoughts would be appreciated.
    10-02-2014 07:32 AM
  1. How to Avoid KitKat OTA on Galaxy Note 3
    By duro1990 in forum Samsung Galaxy Note 3
    Last Post: 05-28-2014, 04:33 PM
