1. RicardoMata178's Avatar
    I've been on several other forums and I know that this is a common problem. I heard rumors of LG replacing it directly rather than going to Verizon and having to go through them. Is this true? It's been a couple of months now, and I can't listen to music. Is my warranty void if I cleaned my Jack out with some solution and a q-tip? Also, if I do get it replaced, will it be free?
    05-13-2014 07:58 PM
  2. Jeffk23's Avatar
    Just push the tip in harder than you think you have to. It will "snap" in. Problem solved. Male piece will be flush to the phone.
    05-14-2014 09:04 AM
  3. buenarc's Avatar
    Thank you for the input. very informative
    05-18-2014 08:35 PM
  4. Jeffk23's Avatar
    Yup. That's what forums are for
    05-22-2014 02:55 PM
  1. OK S4 Mini Rooted Questions Help
    By Corster88 in forum Samsung Galaxy S4 Mini
    Last Post: 06-29-2014, 07:08 AM
  2. Just got the S5 have some questions
    By iamloco724 in forum Samsung Galaxy S5
    Last Post: 05-14-2014, 12:02 AM
  3. Replies: 10
    Last Post: 05-13-2014, 06:45 PM
  4. Lg Optimus F3 LTE support. (Won't turn on or charge)
    By Walkingbad in forum LG Optimus Series
    Last Post: 05-13-2014, 04:57 PM
