Results 1 to 13 of 13
    Tex_Norseman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery after Kit Kat
    So I upgraded my phone to Kit Kat, then did an FDR. I also disabled Android Device Manager, but battery life is still not what is was with JB. I heard people say give it a couple of days to settle. Is this true, or should I expect this sort of performance now that I upgraded?
  2. #2
    AKFL3TCH3R's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery after Kit Kat
    I did a factory reset after the update. It improves the battery life a ton. Mine averages 22 hours with 8 hours of screen on time usually.
  3. #3
    AKFL3TCH3R's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Or more if I don't use it as heavily
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Already did a factory reset, anyone else have any ideas?
    Sent from my VS980 4G using Tapatalk
  5. #5
    fonger13's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It can take a week or two to settle down, my idle drain was 4% per 8 hrs pre KK, it was about 35% per 8hrs in the week following the updates, now it's back to 3-4%. If you just upgraded last week, I would wait another week or so before worrying about the increase in battery drain.
    Edit: I did not do any FDR, just upgrade, reboot a few times over the week.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok fonger I'll give your suggestion a try.
  7. #7
    JJ Jones's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You could also put it into safe mode for a day or overnight to see if battery drain lessens or not. If it's less, then you know you have a rogue app that's not playing nice with the update.
  8. Thread Author  Thread Author    #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dumb question, how do I enter safe mode? I'm rooted, but have standard recovery. I opted out of TWRP this time.
  9. #9
    JJ Jones's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Tex_Norseman View Post
    http://m-support.verizonwireless.com...7334.tp_3.html
  10. Thread Author  Thread Author    #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So far I've done factory reset twice, and for location I have it set for battery saving. Any way to revert to Jelly Bean?
  11. #11
    htcincredible's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just did this and it seems to make my phone run better and I hope it improves battery life thanks for posting that
  12. Thread Author  Thread Author    #12
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    still having quicker than what I consider normal battery drain, any ideas?
  13. #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am using the snapdragon batteryguru and that seems to help out
  1. Battery Question.
    By parkerd97 in forum HTC One M7
    Last Post: 05-23-2014, 01:27 PM
  2. Lost Phone found after Insurance claim ESN question
    By knewman511 in forum Samsung Galaxy S4
    Last Post: 05-22-2014, 10:12 AM
  3. Battery or device?
    By Carla Davidson in forum Samsung Galaxy S3 Mini
    Last Post: 05-21-2014, 11:06 PM
  4. Old SD card? Mediaserver maybe draining your battery!
    By jackoceanz in forum HTC One M8
    Last Post: 05-21-2014, 08:20 PM
  5. Screens turns off after a few seconds
    By Rakesh Patel4 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 05-21-2014, 07:51 PM
