1. leozdad's Avatar
    Over the past few weeks my battery life starts to dive first thing in the morning (6am) and is down to 20% at around 8pm, I only check Facebook a few times and send maybe 5 texts through the day, my battery use was great until the kk update , I did a FDR after the kk update as was suggested here in the forums, my battery graph just nosedives in the morning and continues down like there is a continual drain on it .
    Any helpful suggestions to rectify battery life?
    Dave: Sent from my Nexus 7
    05-26-2014 11:36 AM
  2. SpookDroid's Avatar
    Can you post a picture of the batt stats? What's your 'top 3' battery chompers?
    05-26-2014 12:05 PM
  3. leozdad's Avatar
    Screen 42%, cell standby 13%, phone idle 7%, Google play services 6%
    05-26-2014 12:12 PM
  4. SpookDroid's Avatar
    Sounds consistent for a phone that's mostly 'sleeping', but then it shouldn't last so little... On your batt stats, does the device appear as 'awake' during screen-off?
    You could also try to to do clear cache on Google Play Services, just in case, but I thought it would have been on a higher spot if it were the culprit...
    Are any options that were once 'off' now 'on'? Like location services using GPS all the time or something like that?
    rdearth53 likes this.
    05-26-2014 01:57 PM
  5. acejavelin's Avatar
    It really sounds like your phone isn't sleeping properly... Are you rooted? Have you installed GSAM, it provides much more information.
    Sent from my Nexus 4 using Tapatalk
    05-26-2014 07:31 PM
  6. leozdad's Avatar
    Here is a screenshot
    05-27-2014 08:21 AM
  7. leozdad's Avatar
    Under Google play services the keep awake time is the biggest time
    05-27-2014 08:38 AM
  8. dcleveng's Avatar
    I notice you are only on 3G, are you perhaps in a poor signal area and switching back and forth between 3G and 4G? That can have a detrimental affect on your battery life. I know when I travel through an area with poor signal, it does have a negative impact on my battery life. Just a thought.
    05-27-2014 09:13 AM
  9. SpookDroid's Avatar
    Well, now Play Services has shot up to number 2 spot... Try clearing the cache for it or Uninstalling Updates, reboot, let it re-update itself and then reboot again.
    05-27-2014 09:50 AM
  1. Replies: 12
    Last Post: 02-18-2016, 03:12 AM
  2. Massive battery drain when using USB Tethering (KitKat)
    By Pedro BT in forum Android 4.4 KitKat
    Last Post: 06-03-2014, 02:28 AM
  3. Juice Defender Has Given Me Absolutely Brilliant Battery Life
    By PsychDoc in forum Samsung Galaxy S5
    Last Post: 05-28-2014, 10:32 AM
  4. New G3 video released by LG
    By Mac58 in forum LG G3
    Last Post: 05-26-2014, 11:56 AM
  5. Note with Android 4.3 restarting and discharging battery
    By Ronald Geiken in forum T-Mobile Galaxy Note 2
    Last Post: 05-25-2014, 08:29 PM
