1. Joey Esquivel's Avatar
    I was trying to install cyanogenmod but im still very very new to all this, i was watching and following this video and when i rebooted after installing the rom it stuck at loading the LG logo then vibrating and booting back to the lg screen over and over again
    06-27-2014 12:02 AM
  2. Ronnie2's Avatar
    You didn't kill your phone, it's just in a boot loop. In recovery, make sure that you wipe /system partition and the /cache partition before flashing CM (Cyanogenmod). You did make a backup before doing anything right?
    Sent from my beastly LG G2 using Tapatalk
    06-27-2014 12:28 AM
  3. Ronnie2's Avatar
    I think you have the basics down, just have to make sure you follow the instructions to the letter. If you are having trouble send me a PM or post back here, I'd be happy to help. I've flashed roms on tons of different phones over the years. It all seems kind of complicated but once you have it down you'll be flashing roms like a pro in no time. Just remember if your phone still turns on it can always be fixed. Don't get too frustrated, even I have trouble sometimes. There are tons of users on this forum like me that are here to help!
    06-27-2014 12:38 AM
  4. Kelly Burby's Avatar
    Well, yes you are correct you have killed your phone ! Well the video looks quite good and I think the problem might be somewhere else! Do one thing try doing the same again and if that doesn't help you head over to the XDA thread and follow the steps they have mentioned. (See more over here). Let me know if that helps you out !
    06-27-2014 12:46 AM
  5. acejavelin's Avatar
    Are you installing the VS980 specific build of CM? If not, you will have issues, Information: LG G2 (Verizon) ("vs980") - CyanogenMod
    06-27-2014 10:17 AM
  6. Joey Esquivel's Avatar
    I tried it again from that build but it still goes into the boot loop. Im doing this all from the phone since i dont have access to a PC just a chromebook
    06-27-2014 07:08 PM
  7. Joey Esquivel's Avatar
    Also i rooted using towelroot cause it could root it without needing a pc or anything
    06-27-2014 07:10 PM
  8. simon_lefisch's Avatar
    What version of android are you on? KK or jb?
    07-02-2014 10:00 AM
  9. Joey Esquivel's Avatar
    4.4.2 KK
    07-02-2014 09:55 PM
  10. simon_lefisch's Avatar
    4.4.2 KK
    The official CM nightlies are not made for KK. Even tho they are 4.4, they still run off of 4.2 source code. Install the build from the thread below. It is built off of 4.4 sources.
    http://forum.xda-developers.com/show...php?p=51570392
    07-06-2014 11:10 AM
  11. mumfoau's Avatar
    So that's why I bootlooped both times I tried to install CM!? Silly me!
    07-06-2014 04:38 PM
  12. simon_lefisch's Avatar
    If you're using the official nightlies from the CM website then yes. The thread I posted earlier is an unofficial CM build based off the 24a update (official KK).
    Also, check out the Mahdi ROM thread (under the G2 original android development section). I've been running it for a few months now and have never looked back to go to stock. Its stable and smooth
    07-06-2014 04:56 PM
  13. mumfoau's Avatar
    Dang it Simon! Lol Now I'll likely end up give that a go! Lol
    07-06-2014 05:41 PM
  14. simon_lefisch's Avatar
    Haha do it! Here, I'll make it easy for you....
    Here's the Mahdi thread
    http://forum.xda-developers.com/show...php?p=48954210
    Here's the gapps
    http://forum.xda-developers.com/show...php?p=44417509
    Make sure to read the OP in Mahdi. Happy flashing
    07-06-2014 05:45 PM
  15. mumfoau's Avatar
    [ROM] [4.4.4] [D800/801/802/803/LSVS980/F320] Mahdi-Rom [06/28] - xda-developers
    Here's the gapps
    [GAPPS][4.4.x] OFFICIAL Up-to-Date PA-GOOGLE APPS (All ROM's) [2014-07-02] - xda-developers
    I'm downloading the files now. SMH lol
    07-06-2014 06:37 PM
  16. simon_lefisch's Avatar
    You have a custom recovery installed right? Like TWRP? Meaning you downgraded the bootloader to 12b?
    07-06-2014 06:54 PM
  17. mumfoau's Avatar
    I do have TWRP installed using AutoRec! Just booted to recovery to flash this. Then I'm done... I'll have Stock 4.4.2, The G3 Rom and Mahdi Nandroids and I'll not look at flashing again. LOL
    ffejjj likes this.
    07-06-2014 07:31 PM
  18. mumfoau's Avatar
    Thanks to Simon and the Mahdi ROM recommendation I now essentially have the Verizon "Nexus" I've been wanting!
    07-06-2014 08:44 PM
  1. Phone crashed
    By RionDunn in forum Samsung Galaxy S5
    Last Post: 07-02-2014, 08:54 AM
  2. Help!
    By zactimusprime19 in forum HTC One M8
    Last Post: 06-28-2014, 05:01 PM
  3. Can you buy phones overseas and have them work in australia.
    Last Post: 06-27-2014, 01:06 AM
