1. Kimberly1998's Avatar
    I saw my notification light blue but no notification came up in my notification bar.why does this happen? Also I want to know what the colors mean?
    07-05-2014 10:45 AM
  2. acejavelin's Avatar
    The colors depend on the app, blue is usually Facebook or a calendar event, sorry but I don't remember the others... Or you can just get the LightFlow app and set it up the way you want.
    07-05-2014 10:53 AM
  3. MolecularGraph's Avatar
    On mine, blue is for Facebook or Bluetooth, light blue is for when you double tap the screen on, green is text messages and red is low battery. I know there are done apps that let you pick custom colors.
    Sent from my VS980 4G using AC Forums mobile app
    07-05-2014 11:39 AM
  4. Kimberly1998's Avatar
    The thing is the blue light comes up when theres no notifications. Like I dont have a calender schedualed thing on. And theres no Facebook notification either. Sometimes my instagram wont load something when in my notification bar there is the instagram logo but when I go to my instagram and try to refresh nothing comes up
    07-11-2014 09:32 AM
  5. Tex_Norseman's Avatar
    Kimberly with 4.4.2, it also comes on now when Bluetooth connects(blue) , and disconnects(red). Maybe that is what your are experiencing.
    07-23-2014 06:56 AM
  6. scottysize's Avatar
    Just disable it, then you won't see the colors
    Sorry. That's not helpful is it. If you unlock the screen, the notification light stops blinking until the next time you receive a notification. If you want to customize the lights, there are apps out there for this.
    Just an FYI that you might not know exists:
    How to Set a Notification LED Color for a Specific Contact on G2
    On LG G2 other than assigning special alarm for a contact, you can select a notification LED color for that specific contact. To change the LED color as call notification, do as follows:
    1. Go to Contacts application
    2. Tap the contact you want to change
    3. Press the Pen button to enable modifying
    4. Scroll down and under Notification LED, select the new color
    07-23-2014 08:27 AM
  7. lingcod777's Avatar
    Is there a Bluetooth device disconnecting / reconnecting? That was a mystery LED notification for me.
    Sent from my VS980 4G using Tapatalk
    07-24-2014 01:52 AM
  1. Photos from Google Drive are showing up on my android
    By tarekahf in forum Ask a Question
    Last Post: 07-08-2014, 11:51 AM
  2. why wont my new tab 4 not charge or turn on?
    Last Post: 07-07-2014, 12:51 PM
  3. NeeD HelP FoR MY GalaxY GranD !!!!
    Last Post: 07-05-2014, 09:40 AM
