1. haxsaw67's Avatar
    I just purchased a new LG G2 phone, I cannot get the ignore with message to send the text message on incoming calls during lock screen, works when the phone is unlocked an d in use, I went into setup options to make sure it is still turned on, when a call comes in, it gives me the option to ignore it, I select send beside the text I want and then it goes back to the locked screen, I then have to unlock the phone, go to messages and send the message..
    How do I fix this?
    07-18-2014 10:34 AM
  2. acejavelin's Avatar
    Do you have any type of security on the lock screen, PIN, pattern, or password? It will not work with security turned on.
    07-18-2014 10:52 AM
  3. haxsaw67's Avatar
    yes, i have a pattern lock screen..
    07-18-2014 12:05 PM
  4. acejavelin's Avatar
    That's the issue i would bet, Turn it off and have someone call you... I would bet it works fine.
    07-20-2014 07:49 AM
  1. SD Encryption won't turn off - Sprint M8 with v4.4.3
    By Overboost in forum HTC One M8
    Last Post: 07-21-2014, 12:33 AM
  2. android.com.phone stopped working
    By suraba in forum LG Optimus L
    Last Post: 07-20-2014, 02:37 PM
  3. 4.13.651.3 - It's unlocked now but I can't find a recovery that works.
    By gpdaddy95 in forum HTC EVO 4G LTE Rooting, Rom's, and Hacks
    Last Post: 07-18-2014, 10:25 AM
  4. Replies: 0
    Last Post: 07-18-2014, 09:48 AM
  5. Sync simple folders from microSD with Kies (Galaxy S4)
    Last Post: 07-18-2014, 09:22 AM
