1. Paul Jolin's Avatar
    Why can i not charge my phone using my car's USB port? I am using the factory charging cable that came with the phone. It tells me to use a compatible cable.
    07-28-2014 12:46 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Car USB ports may not have a charging circuit, since they probably expect you to use the DC power outlet.
    07-28-2014 12:48 PM
  3. acejavelin's Avatar
    Many car ports only supply 500ma, which isn't sufficient to charge the G2.
    07-28-2014 01:54 PM
  4. simon_lefisch's Avatar
    You need to purchase a car charger that is a minimum of 1.8A (1800mA) to charge the phone. I purchased a rocketfish charger from best buy that is 2A and it charges just as good as my wall charger.
    07-28-2014 11:37 PM
  1. Replies: 5
    Last Post: 07-30-2014, 11:18 AM
  2. Time Out Setting issues
    Last Post: 07-28-2014, 03:47 PM
  3. S4 Kit Kat Issues (WiFi and Data)
    By MJ209 in forum Android 4.4 KitKat
    Last Post: 07-28-2014, 12:12 PM
  4. my samsung discover won't charge in my car
    Last Post: 07-28-2014, 12:09 PM
  5. Email Issue Getting old mail on new Galaxy S5
    By bearle142 in forum Samsung Galaxy S5
    Last Post: 07-28-2014, 10:57 AM
