Things have improved quite a bit the last few days, by me doing absolutely nothing different? Dunno, can't explain.
I may have discovered the "glich" for me in power usage - I noted that when my phone uses the 3G network it heats up and increases power usage tremendously. In 4G usage the phone is cool and power usage is reasonable. I have the network setting as LTE/CDMA .I am a light user-no streaming, just text and phone and very light net usage. The phone auto switched to 3G this morning and dropped 35% in 3 hours (100% to 65%), heating up in the process, i.e., warming to the touch without active use. It has auto switched back to 4G and has cooled to the touch.
What's this Lte cdma setting I've heard about. I can't find it anywhere?
What made you decide to go to JB rather than kitkat? Just curious.I rooted my G2 and flashed jellybean back on it. After 26+ hours I am at 68% battery life and no spikes in the battery drain. I was charging twice a day on lollipop and had been turning the phone off at night just so I could avoid charging it further. I don't think there is any setting on lollipop to stop the crazy battery drain. My phone was out of warranty so I went ahead with trying to save it and it worked. I had never rooted or flashed a phone before but it was not that difficult and really minus the reading time to research it took about 20 minutes to get it back to a great phone again. Everything works great now just like it used to before the updates. It was kind of a drastic step but worth the effort.
