1. tattooedchicken's Avatar
    I have lost all ability to use my keypad. EVERYTHING else on the phone works. I cant pull up the key pad at all. I have resorted to going to quick notes, writing my txt, doing a screen shot, and, attaching it as a pic in message....My software is updated, any other suggestions???
    03-11-2014 10:33 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Maybe on a decsktop PC send another keyboard to your phone, like Google. Maybe that will help.
    03-11-2014 10:56 AM
  3. hokie_prof's Avatar
    You might also try going into your settings and checking to see which keyboard you have selected or check7ng tonsee if you have accidentally deselected all keyboards. Maybe you can switch keyboard options ? On my phone that setting is called "language and input." It might be something different on the Intuition.
    03-12-2014 07:40 AM
  1. Let me help you root [Root Man]
    By Upstreammiami in forum Samsung Galaxy S4
    Last Post: 03-20-2014, 11:50 AM
  2. Let me help you root [ROOT MAN]
    By Upstreammiami in forum Sprint Samsung Galaxy S4
    Last Post: 03-11-2014, 10:25 AM
  3. Let me help you root [Root Man]
    By Upstreammiami in forum AT&T Samsung Galaxy S4
  4. Let me help you root [Root Man]
    By Upstreammiami in forum T-Mobile Samsung Galaxy S4
    Last Post: 03-11-2014, 09:56 AM
  5. Replies: 1
    Last Post: 03-11-2014, 07:59 AM
