Results 1 to 4 of 4
    Default after rooting problems with lights on front
    After rooting I noticed the front search, app, home, etc buttons aren't lighting up like normal. They function when pressed but lights aren't working. Any ideas?
  2. #2
    S.Meezy's Avatar
    Posts
    ROM
    Revo DeCrap 1.1
    Default
    Quote Originally Posted by zombiearmy View Post
    Menu settings display brightness. Turn auto off. After that, once it stops working again, plug it into ur computer and you should be good to go!
    VS910 4G Kangwich
    Phones are my drug of choice
    Thanked by:
    Default Re: after rooting problems with lights on front
    Works great thanks!. Sorry for the repeat, especially if there's been a fix posted already but any news on Getting the front search hardware button to go to google once the apk is installed and bing has been "frozen"?
  4. #4
    S.Meezy's Avatar
    Posts
    ROM
    Revo DeCrap 1.1
    Default
    There's a ROM @ xda, gingervolt that does this and more... eliminates some functionality of the phone like Facebook and Twitter for LG and a couple of other stock apps... worth a read at least.
    VS910 4G Kangwich
