Results 1 to 7 of 7
    Default Air view & Air gesture enabled. Doesn't work. Anyone else?
    Sent from my SM-N900V using AC Forums mobile app
  2. #2
    Default Re: Air view & Air gesture enabled. Doesn't work. Anyone else?
    doesn't work for me. I do have it on in the settings
  3. #3
    The Air view is pretty consistent for me, but the air gestures were not worth looking like a fool waving at my phone to get something to work so I disabled it.
    almostfriday likes this.
    I figured it out. For example airview... Settings / Motions and gestures. make sure it's on then to the left of on tap to open set to auto.
    for Air gestures make sure you do the same and your hand must float over the sensor at the top of the phone just under the samsung name.
    Jim
  5. #5
    geex4's Avatar
    Posts
    Global Posts
    3 Global Posts
    I finally get it!! Your Palm has to touch the screen you can't just waive it over. That took me forever to figure out lol.
  6. #6
    after upgrade to KITKAT, I found my air gesture is disable each time I clear my ROM.......I have to manually enable it every time I clear ROM. Anyone encounter same issue??? please help
  7. #7
    Yes, same ****, if I set de Air gesture on Enable, I dont get the sybol in the upper screen.
    It only works in the testmode (?). Dont no what to do.
  1. screen capture/shot not working
    By andyr3ad in forum Samsung Galaxy Note 3
    Last Post: 02-21-2014, 02:11 PM
  2. Can anyone identify this app?
    By RavenMind in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-26-2013, 02:20 AM
  3. How to adjust volume with gesture
    By jeffruby in forum LG G2
    Last Post: 10-17-2013, 09:06 AM
  4. Screen blanking stops bluetooth headset from working
    By William Hay in forum General Help and How To
    Last Post: 10-17-2013, 06:38 AM
  5. Replies: 1
    Last Post: 10-16-2013, 09:44 PM
