Does charging normally take so long to charge?
dt81
746
9
I plugged my phone in at 29 percent and it's now been about two hours and it's only at 39. I am using the stock charger out of the box on the wall.. I thought it's suppose to be charge very quickly?
dragonsamus
972
35
Two hours and only ten percent? There's a problem. The phone should charge fully in less than three hours. Try a different outlet.
Sent from my SM-N900T using AC Forums mobile app
took2089
196
Yeah big time issue.
Sent from my iPhone using Tapatalk - now Free[/URL
ccpopham
344
Another thing may not be pertinent to your situation, but when purchasing usb charging accessories, go with a high amperage. This will allow for faster current and charge time. I have a filtered 2A rated usb cord. The filter is the thicker part toward one end of the cable and I have a 3A wall plug and car charger. With this combination my charging time using just USB is incredibly fast compared to the normal usb stovk chargers. Although the usb 3 is still faster on the note 3, it is not a total blowout by the usb 3 charger.
Sent from my SM-N900V using AC Forums mobile app
dt81
746
9
I was using the cord and charger from the note 3 box. It was it's first charge out of the box. I wasn't using the phone for the two hours I had jt sitting. I'll see how it goes tonight.
But I am right when I read that the USB 3.0 charges it much faster? Which the cord from the box is a 3.0 right?
dragonsamus
972
35
USB 3.0 charges faster connected to a pc vs USB 2.0 (1,000 mAh vs 500 mAh).
The note 3 when using the stock charger should be charging at 2,000 mAh.
Download an app called battery monitor widget and see what the supplied mAh is when connected to your charger.
ccpopham
344
I would also remove your battery for a minute and then reinstall it. That will sometimes help.
OKATVRIDER
95
4
I timed my full charge today....2 hrs and 14 min from 1% to 100%...not bad at all....I've been on the phone 3 hrs and 38 min and have 81% left...I swapped out for a new note 3 last night since last note 3 had issues...hoping the battery life on this new note 3 will be just as good as my last.
unirockers
