Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Like Tree4Likes
    CompMan2012's Avatar
    Banned
    Posts
    Global Posts
    272 Global Posts
    Default Issue Opening the Same App Twice in Multi Window
    ...We're supposed to be able to use the same app in the split window screen... what a load of crap!
    has anyone else noticed this?????
  2. #2
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Carrier
    CM 10.2
    Default re: Issue Opening the Same App Twice in Multi Window
    I have yet to really play with it. The one time I did it worked as advertised.
    Banned
    Posts
    Global Posts
    272 Global Posts
    Quote Originally Posted by Haalcyon View Post
    It doesn't work with my phone.... and I tried different apps too. I'm curious to see how many other users have the same problem.
  4. #4
    Mine works fine.
    Sent from my SM-N900V using AC Forums mobile app
    Banned
    Posts
    Global Posts
    272 Global Posts
    Quote Originally Posted by ccpopham View Post
    Mine works fine.
    Seriously? Then mine is the only one not working properly? I can't believe that.
    Let me explain this one more time...
    I'm trying to use the same exact app on a split screen... Meaning I want to have 2 separate text messages sessions going on at the same time!
  6. #6
    GtoJon's Avatar
    Posts
    Carrier
    Stock Note 2
    Mine works too
    Cheers, Jon
  7. #7
    Here is a screenshot of my internet browser open in multi window,Click image for larger version.
  8. #8
    not all apps will do it only Internet and Some chat apps,according to help on multi window,
    GeekNews likes this.
  9. #9
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Carrier
    CM 10.2
    Quote Originally Posted by CompMan2012 View Post
    I opened one window, then opened a message app in the second window, then switched. Not sure why I had to do it that way but worked just as easily.
  10. Thread Author  Thread Author    #10
    Banned
    Posts
    Global Posts
    272 Global Posts
    Quote Originally Posted by GtoJon View Post
    Mine works too
    No F'n way!!!!
    Cheers, Jon
  11. Thread Author  Thread Author    #11
    Banned
    Posts
    Global Posts
    272 Global Posts
    Is there a setting for this??? Please help!
  12. Thread Author  Thread Author    #12
    Banned
    Posts
    Global Posts
    272 Global Posts
    I'm trying to do it with the native texting app like they demonstrated
  13. #13
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Carrier
    CM 10.2
    Have you tried toggling Multi-Window off and then back on again in the notification toggles?
  14. #14
    On my Note 8 which is rooted I have a multi window app that is from the app store which allows a lot more Versatility with the Multi window I have not yet rooted My note 3 to try it On here yet,
  15. Thread Author  Thread Author    #15
    Banned
    Posts
    Global Posts
    272 Global Posts
    definitely!
  16. #16
    GtoJon's Avatar
    Posts
    Carrier
    Stock Note 2
    Sorry .... ALL of us are confused ..... you want to run 2 browsers or 2 facebooks at the SAME time .... just tried that & you cannot run 2 of the SAME apps at the SAME time Bummer Dude! & I doubt any of the others can do this either Maybe they will look at this thread & say "Give it to them"
    Cheers, Jon
  17. #17
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Carrier
    CM 10.2
    Cheers, Jon
    Than what is this below? It's two internet browser windows.
  18. #18
    GtoJon's Avatar
    Posts
    Carrier
    Stock Note 2
    Doesn't work for me or the OP
    Cheers, Jon
  19. #19
    It does work with internet browser and it says some texting apps. I opened to web browsers from multiwindow without a problem.
  20. #20
    GtoJon's Avatar
    Posts
    Carrier
    Stock Note 2
    I just found that out ... non of the others in the Multi-Window bar will work that I have seen Kinda sucks when you can't depend on something that should naturally work!!
    Cheers, Jon
  21. Thread Author  Thread Author    #21
    Banned
    Posts
    Global Posts
    272 Global Posts
    Cheers, Jon
    It's messed up because I was watching the key-note presentation when they announced the note 3 and they demonstrated that as one of the key new features! I'm truly upset over this.
  22. #22
    How are you attempting to accomplish this? I open the multiwindow from the home screen and drag the internet browser onto the screen and navigate to whatever page. I then go back to the multiwindow and drag another internet browser onto the lower half of the screen and navigate to another page.
  23. Thread Author  Thread Author    #23
    Banned
    Posts
    Global Posts
    272 Global Posts
    I'm talking about using 2 texting apps at the same time. Just like the web browsing that you're talking about. We should be able to have 2 text conversations simultaneously and share info (like addresses and pictures) between the Windows.
  24. #24
    2 things:
    • Thread title reminds of the famous Joe Pesci scene from Goodfellas where he's messing with Henry at the restaurant.
    • I hate vague...thread titles.
    sux2bu likes this.
  25. #25
    Ah got cha. I tried with the stmessaging app and it was a no go as well as with handscent. I saw anothee possible sms app called ninja. I will check into it and se if it doed multi window.
  1. Any good messaging apps?
    By ipwn3r456 in forum Samsung Galaxy S3
    Last Post: 11-02-2013, 07:53 AM
  2. Replies: 3
    Last Post: 10-28-2013, 11:47 PM
  3. roms to fix headphones button issues?
    By NoTe3 in forum AT&T Samsung Galaxy Note 3
    Last Post: 10-28-2013, 06:55 PM
  4. My phone has gone crazy in the last week.
    By Dustin Tracy in forum HTC EVO 4G LTE
    Last Post: 10-28-2013, 12:29 AM
  5. In what file are "Memo" saved?
    By hell911 in forum General Help and How To
    Last Post: 10-27-2013, 11:48 PM
