Results 1 to 8 of 8
    Nayhova1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Verizon Samsung Galaxy Note 3 - Sound issue with play music.
    Has anyone had any issues with the audio when using Google play music? I love the service and subscribed but I'm having an issue with the audio playing very low. I can toggle the EQ off and the sound goes up but I lose the EQ sound. If I power cycle the device the sound will go back to normal. Just wondering if anyone had any issue like this as well.
    Sent from my SM-N900V using AC Forums mobile app
  2. #2
    Derek Orange's Avatar
    Posts
    Global Posts
    4 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Verizon Samsung Galaxy Note 3 - Sound issue with play music.
    Having the same issue. Anyone have any solutions?
  3. #3
    runamuck0870's Avatar
    Posts
    Global Posts
    189 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No issues with volume over BT or via the headphones.
    My only issue is sometimes songs mysteriously go into "fast playback" mode and artists sound like chipmunks. But I think that has to do with LTE service.
  4. #4
    byrds8's Avatar
    Posts
    Global Posts
    704 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Every Android phone I have ever had had this same issue. You can use the EQ but you cant turn most any slider to max or else the volume drops. I never could figure out why that happened and it only seemed to in Play. Either way its normal for the OS.
  5. #5
    hawkeye680's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't think it is normal at all. I am having a new issue, just the past couple of days, and it is only when an AUX cable is plugged in. Doesn't do it over my BT ear buds.
    If I have it plugged in via aux cable in my truck and skip to the next track, the volume goes down to where I can't hear anything. If I unplug, play through the speakers, then plug back in, it's fine until I skip to the next track. Driving me nuts.
  6. #6
    Rob Weisenbach's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hawkeye680 View Post
    - - - Updated - - -
    I just got the note 3 and I have the same issue... Did you find a work around? Thanks
  7. #7
    hawkeye680's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's been a while now but I think it was addressed by an update to Music.
  8. #8
    vzw8830's Avatar
    Posts
    Global Posts
    102 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm still having this issue, works fine over bt. But headphone jack does it.
  1. Galaxy Tab 10.1 3G - Question about rooting? help
    By David Santos2 in forum General Help and How To
    Last Post: 11-15-2013, 09:54 AM
  2. Samsung Galaxy S4 - 64gb sd card showing as full
    By Ciaran McNally in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 01:39 PM
  3. Samsung Galaxy S4 - Open case causes black screen of death?
    By mahler9 in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 10:11 AM
  4. Column headings on SD card all music-related
    By jedi44 in forum Samsung Galaxy S4 Google Edition
    Last Post: 11-05-2013, 08:45 AM
