Post Verizon Note 3 band 4 speed tests
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
For those that updated to the latest update and are using band 4, what speeds are you seeing? These are speeds at my work which is in a densely populated area. Note the band 13 speed tests at the bottom.
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Eddster
338
Re: Post Verizon note 3 band 4 speed tests
71 DOWN!!!! WOW!! I'm in the DC area and the highest I got was 23-25...which is what it was before the iPhones got LTE. LOL
I had been averaging around 9-10 for about the last year. So, I guess the activation of the AWS band technically doubled my speeds? *shrugs*
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Snap a screenshot! :D.
Sent from my T-Mobile Note 3 using AC Forums.
Central n ohios best
424
We don't need u vzw people clogging up band 4 like y'all did with 700 lol jkjk.
Sent from my T-Mobile LG Escape running 4.1.2 using Tapatalk 2 (Central n Ohio Austin IL)
rrabago
16
After update AWS radio on in the Seattle area and the Hotspot still working using Foxfi :)
rrabago
16
So did you have to uninstall and reinstall Foxfi?? I'm in the Seattle area too, but I use the hotspot for my commute to work. Can't lose that.
Sent from my Black on Black Verizon Note 3
No I did not. It was the first thing I tried after the update. I've read on other forums that some are having to do so but it does continue to work after uninstalling and reinstalling if you need to. Good luck!
ki11ak3nn
554
Hmm Ok I guess I'll give the update a shot then.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Here is a band 4 speed test with light load.
jim2112
184
I have done a few at different locations. uploadfromtaptalk1389038966980.jpg
Sent from my SM-N900V using Tapatalk
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
I know for some it's obvious that you are on band 4. But, how can you tell for sure? Is everyone just going by speeds or only the areas known to have AWS running?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
You can monitor band by following the instructions here.
Other than that Band 13 max is 72 mbps, and uploads around 20mbps. If you see speeds faster than that, then you would be on band 4.
http://forums.androidcentral.com/showthread.php?t=335201
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
Thanks. I was reading other articles online earlier. I am assuming that you need to be rooted for any of these methods to work?
I didn't root this phone because I am not sure if it would void my Edge contract.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Yes you would need root to check band, though you can "check" based on speed
TheMacs
474
10
I hate these threads... Makes me envious of the speeds, and annoyed at the cost I'm paying for the slow(er) lane. :confused:
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
Here's the thing...I checked speeds when I first got my phone on 10/10 and got 51 Mbps download. On 10/14, I got 54. I haven't been able to crack 30 Mbps download since then. At the time, I thought maybe our area (metro Detroit) had band 4 LTE already. Now, I am just confused. Most reports say no Detroit yet, but a few I have seen says it does have it.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Here's the thing...I checked speeds when I first got my phone on 10/10 and got 51 Mbps download. On 10/14, I got 54. I haven't been able to crack 30 Mbps download since then. At the time, I thought maybe our area (metro Detroit) had band 4 LTE already. Now, I am just confused. Most reports say no Detroit yet, but a few I have seen says it does have it. http://img.tapatalk.com/d/14/01/09/qa2y8e5a.jpg
It would be easiest to check at light load times like in the wee hours.
Also even though band 4 may be deployed in your city, it might not be deployed in your area.
dontlookatme
568
7
certain spots i am able to get 50 mb/s down and that is awesome, but the issue is i only pass by that area once every night on my way home. every where else i get good speeds. ill upload as soon as i am off work.
DragnDon
