01-16-2014 11:42 AM
31 12
tools
  1. dpham00's Avatar
    For those that updated to the latest update and are using band 4, what speeds are you seeing? These are speeds at my work which is in a densely populated area. Note the band 13 speed tests at the bottom.
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    Attached Thumbnails Post Verizon Note 3 band 4 speed tests-uploadfromtaptalk1386790249270.jpg
    12-11-2013 01:32 PM
  2. cjsmoove's Avatar
    Much better even though my upload is not up to par.
    12-11-2013 01:44 PM
  3. Eddster's Avatar
    71 DOWN!!!! WOW!! I'm in the DC area and the highest I got was 23-25...which is what it was before the iPhones got LTE. LOL
    I had been averaging around 9-10 for about the last year. So, I guess the activation of the AWS band technically doubled my speeds? *shrugs*
    12-11-2013 05:30 PM
  4. Almeuit's Avatar
    Snap a screenshot! .
    Sent from my T-Mobile Note 3 using AC Forums.
    12-11-2013 05:41 PM
  5. Central n ohios best's Avatar
    We don't need u vzw people clogging up band 4 like y'all did with 700 lol jkjk.
    Sent from my T-Mobile LG Escape running 4.1.2 using Tapatalk 2 (Central n Ohio Austin IL)
    12-11-2013 06:11 PM
  6. Eddster's Avatar
    12-11-2013 07:03 PM
  7. rrabago's Avatar
    After update AWS radio on in the Seattle area and the Hotspot still working using Foxfi
    12-11-2013 07:52 PM
  8. ki11ak3nn's Avatar
    So did you have to uninstall and reinstall Foxfi?? I'm in the Seattle area too, but I use the hotspot for my commute to work. Can't lose that.
    Sent from my Black on Black Verizon Note 3
    12-12-2013 01:59 AM
  9. rrabago's Avatar
    No I did not. It was the first thing I tried after the update. I've read on other forums that some are having to do so but it does continue to work after uninstalling and reinstalling if you need to. Good luck!
    12-12-2013 07:24 AM
  10. ki11ak3nn's Avatar
    Hmm Ok I guess I'll give the update a shot then.
    12-12-2013 05:24 PM
  11. dpham00's Avatar
    Here is a band 4 speed test with light load.
    Attached Thumbnails Post Verizon Note 3 band 4 speed tests-uploadfromtaptalk1389018187975.jpg
    01-06-2014 08:23 AM
  12. jim2112's Avatar
    I have done a few at different locations. Post Verizon Note 3 band 4 speed tests-uploadfromtaptalk1389038966980.jpg
    Sent from my SM-N900V using Tapatalk
    01-06-2014 02:10 PM
  13. Nakrohtap's Avatar
    I know for some it's obvious that you are on band 4. But, how can you tell for sure? Is everyone just going by speeds or only the areas known to have AWS running?
    01-06-2014 03:10 PM
  14. dpham00's Avatar
    You can monitor band by following the instructions here.
    Other than that Band 13 max is 72 mbps, and uploads around 20mbps. If you see speeds faster than that, then you would be on band 4.
    [HOW-TO] Enable Band 4 AWS on SM-N900V *REQUIRES ROOT*
    01-06-2014 03:27 PM
  15. Nakrohtap's Avatar
    Thanks. I was reading other articles online earlier. I am assuming that you need to be rooted for any of these methods to work?
    I didn't root this phone because I am not sure if it would void my Edge contract.
    01-06-2014 09:17 PM
  16. dpham00's Avatar
    Yes you would need root to check band, though you can "check" based on speed
    01-07-2014 07:54 AM
  17. TheMacs's Avatar
    I hate these threads... Makes me envious of the speeds, and annoyed at the cost I'm paying for the slow(er) lane.
    01-07-2014 12:36 PM
  18. Nakrohtap's Avatar
    Here's the thing...I checked speeds when I first got my phone on 10/10 and got 51 Mbps download. On 10/14, I got 54. I haven't been able to crack 30 Mbps download since then. At the time, I thought maybe our area (metro Detroit) had band 4 LTE already. Now, I am just confused. Most reports say no Detroit yet, but a few I have seen says it does have it.
    01-08-2014 05:33 PM
  19. dpham00's Avatar
    Here's the thing...I checked speeds when I first got my phone on 10/10 and got 51 Mbps download. On 10/14, I got 54. I haven't been able to crack 30 Mbps download since then. At the time, I thought maybe our area (metro Detroit) had band 4 LTE already. Now, I am just confused. Most reports say no Detroit yet, but a few I have seen says it does have it. http://img.tapatalk.com/d/14/01/09/qa2y8e5a.jpg
    It would be easiest to check at light load times like in the wee hours.
    Also even though band 4 may be deployed in your city, it might not be deployed in your area.
    01-08-2014 07:14 PM
  20. dontlookatme's Avatar
    certain spots i am able to get 50 mb/s down and that is awesome, but the issue is i only pass by that area once every night on my way home. every where else i get good speeds. ill upload as soon as i am off work.
    01-08-2014 08:26 PM
  21. dontlookatme's Avatar
    I thought this phone was capable of 42 mbps max?
    01-09-2014 01:13 AM
  22. dpham00's Avatar
    http://img.tapatalk.com/d/14/01/09/u2unaru4.jpg
    The note 3 is capable of 150mbps where 20x20mhz aws is deployed to its full potential.
    Verizon's backhaul is limited to 150mbps and shared among bands 13 and 4, usually 70mbps for band 13 and 80 mbps for band 4. But there are areas where aws is allotted 100mbps. So currently 100 mbps is the max, limited by the network. But if Verizon provides more bandwidth, then you should in theory be able to reach 150mbps where 20x20mhz aws is deployed to its full potential .
    This isn't my speed test, but just an example
    01-09-2014 08:02 AM
  23. Almeuit's Avatar
    Yep 20x20 is insanely fast.
    01-09-2014 10:14 AM
  24. dpham00's Avatar
    If tmobile and Verizon's plan goes through, there could be 35x35 600 Mhz in the future!
    Though unfortunately, Verizon only has 30mhz aws in Los Angeles.
    01-09-2014 10:22 AM
  25. mfldmike's Avatar
    I really can't wait to try out AWS on the Note 3...I performed a test on my Note 2 and the following was my result...If that's the case AWS should be blazing fast for me...
    Sent from my SCH-I605 using Tapatalk
    Attached Thumbnails Post Verizon Note 3 band 4 speed tests-uploadfromtaptalk1389315886454.jpg
    01-09-2014 07:04 PM
31 12
  1. New Verizon update available to me today?
    By milehigherik in forum Verizon Samsung Galaxy S4
    Last Post: 12-18-2013, 02:21 PM
  2. Verizon 3G / 4G switch widget......
    By roadrat in forum Moto X (2013)
    Last Post: 12-11-2013, 03:34 PM
  3. Ads, posts that are "too specific"
    By Cvc305 in forum Samsung Galaxy S4
    Last Post: 12-11-2013, 02:45 PM
