Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By 4 Star General
    Default Help deletion issue
    I Hv a folder in my gallery with the Picasso icon that's attached to Hangouts and won't allow me to delete the photos within. Only options are download and share. How the h3ll do I get rid off.
    A Note 3 & a Wrangler, life is Grand.
  2. #2
    pdub73's Avatar
    Posts
    Global Posts
    174 Global Posts
    Default
    Sorry I tested and it did not delete
  3. #3
    Default Re: Help deletion issue
    Try this...Google up how to delete Picassa photo's from Google hangouts.....This should take you to a forum about just this...even have a video on it...so it can be done
    Good luck
    Sent from my SM-N900V using AC Forums mobile app
    Thanked by:
  4. #4
    Quote Originally Posted by 4 Star General View Post
    Try the following steps it will work
    1) Go to settings click on Accounts and Sync.
    2) Uncheck Sync Picasa Web Albums.
    3) Come back and click on Applications in the settings page.
    4) Now click on Manage Applications.
    5) In the manage application page click the Menu option ALL.
    6)Scroll down you will find an option called gallery.
    7) Click on the Gallery and clear data. Note: Don't worry your local data won't be deleted.
    9) Thats it check your gallery now there wont be any Picasa web albums in your Gallery.
    Thanked by 2:
    It worked, thnx👍
    CNParrish likes this.
  6. #6
    You will still have to get on a computer and delete the pictures in Picasa as they are still there just not syncing to your phone now.
  1. ATT HSPA+ help
    By Justin967 in forum Google Nexus 4
    Last Post: 12-30-2013, 09:39 PM
  2. Replies: 3
    Last Post: 12-30-2013, 10:10 AM
  3. Amicroe touchtab II help
    By Dicex in forum General Help and How To
    Last Post: 12-29-2013, 09:41 PM
  4. HELP Tmobile APN Settings
    By robbob88 in forum Moto G
    Last Post: 12-29-2013, 01:41 PM
  5. Help! I have problems with Google Accounts
    By Hubert Fortier in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-29-2013, 10:09 AM
B
