Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By LillieBennett
    Default Verizon Galaxy Note 3 - RF Signal meter meaning
    What do the vertical bars actually represent? I am sitting 6 ft away from my Wi-Fi router, but only have 2 bars. I only have 2-3 bars when I turn on 4g, but everything works ok when I use internet and I have never had dropped calls.
    from my "Note 3" on Tapatalk
  2. #2
    Default Re: Verizon Galaxy Note 3 - RF Signal meter meaning
    Your Wi-Fi looks like full signal in your picture. The vertical bars are only your 3g an 4g voice/data signal when Wi-Fi is off. When Wi-Fi is on, it's used for voice only.
    Sent from my SM-N900V using Tapatalk
    I see so many people with with signal issues. I did a factory reset several weeks ago when I kept getting 3g or no service and have not seen the slashed circle since, but I rarely see more than 3 bars. My hubby's note always has at least 3 bars and we're in same service areas all the time. Just trying to avoid a trip to Verizon if there's no real need.
  4. #4
    I don't pay any attention to the graphic in the Status Bar, I have found it very slow to update on the note 3, Go to settings, General, about, device and Click on Status, you well see your actual Signal strength there, for some reason, the status bar graphic seems to be very inaccurate.
    What's considered expected range for our phones in a decent service area?
  6. #6
    Quote Originally Posted by yarnsrj View Post
    http://img.tapatalk.com/d/14/01/14/ta5u4y2a.jpg
    Depends if you're inside (and what the building is made with), outside, how far you are from the cell tower, if the tower is directly visible or behind a hill, etc. Look at Verizon's coverage map and zoom in to your exact location to see how good a signal you should have.
    Bottom line, if you don't have trouble making or receiving calls....then you're fine.
    Sent from my Xoom using Tapatalk
    Ok. That's how I'm thinking to. Sammy has had issues with this before, but my phone is working fine.
  8. #8
    If everything works ok, then don't worry.
    But if you wanted to see signal strength, use an app like "advanced signal status", it would be much more useful than the bars.
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    What does this mean?
  10. #10
    How did you get to that screen? My status only reads dbm and asu
  11. Thread Author  Thread Author    #11
    dpham00 suggested using an app called "advanced signal status". I took a screenshot to post these results, but I don't really know what the numbers represent..
  12. #12
    The signal bars are an average. The db number is most accurate: -120db=no service and -30db the best I've ever seen near a tower and using an amplifier. :-)
    SM-N900V DE
    yarnsrj likes this.
  1. Replies: 2
    Last Post: 04-23-2015, 02:54 AM
  2. Replies: 9
    Last Post: 01-17-2014, 06:01 PM
  3. Note 3 contacts issue. Help anyone?
    By itsaykj in forum Samsung Galaxy Note 3
    Last Post: 01-14-2014, 12:05 AM
  4. Samsung Galaxy Tab 2 not opening Epub or Mobi
    By Acheros in forum General Help and How To
    Last Post: 01-13-2014, 11:05 PM
  5. Note 3: Inexpensive case with good protection?
    By smccloud in forum Samsung Galaxy Note 3
    Last Post: 01-13-2014, 10:53 PM
