Results 1 to 3 of 3
    Will_T's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Phone has stopped connecting to home wifi.
    I have noticed this only since the latest update to the Note 3. Before when I left range of my home wifi the phone would go to LTE and upon returning home, automatically reconnect to my home wifi. Now it goes to 4g when I leave, but does not reconnect when I return home. I think it is turning off when I am away for wifi for an extended period. I do not remember for sure, but I think before, wifi did not actually turn off. I think it just went out of range and then started using it again when I returned home. I don't really recall the specifics except that before I never had to do anything to get it to start using our home wifi network. lt would just automatically reconnect when I got home. Now unless I remember to turn wifi on manually, I could be home all weekend and still be on 4g.
    Below are my advanced wifi settings. Thanks for any suggestions.
    Notify: Off
    Passpoint: Off
    Sort by: Alpha
    Keep on during sleep: Always
    Always allow scanning: Tried both Unchecked and checked
    Auto network switch: Tried bothUnche Checked
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,051 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Phone has stopped connecting to home wifi.
    In case no one has said so, welcome to the forums!
    Have you tried rebooting the device?
    Or disconnecting the wifi and reconnecting?
  3. #3
    Johnny Umphress's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Open your WiFi setting in Settings and select your home WiFi, Select 'Forget'. Then re-open that WiFi again and log back in. I have had to do that once before and it worked.
  1. HTC One: How to install OTA Update? Rooted.
    By Master T in forum HTC One Rooting, ROMs & Hacks
    Last Post: 11-20-2015, 08:05 AM
  2. Replies: 6
    Last Post: 05-21-2015, 12:00 PM
  3. how to get black background
    By la321 in forum AT&T HTC One
    Last Post: 01-19-2014, 05:31 AM
  4. Swype defaults "the" to "The"
    By MattKJackson in forum Motorola Droid Mini
    Last Post: 01-16-2014, 02:03 AM
  5. Replies: 4
    Last Post: 01-15-2014, 10:15 PM
