Results 1 to 7 of 7
    blaze45's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default S3 running terrible! Please recommend fixes
    This seems to happen to all my android products and its frustrating.
    The navigation doesn't work. I have tried downloading it and deleting it. Still wont work like it should. I checked all the screws and they were tight on the phone.
    Since the new software update (kit kat?), it is running INCREDIBLY slow. I can barely stand it.
    What are my options for fixing the navigation situation?
    What can I do to speed my S3 for daily functions (closing and opening apps ect)
  2. #2
    daves221's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S3 running terrible! Please recommend fixes
    Wrong forum unfortunately...you're in the note 3 forum here, not the s 3
  3. #3
    xceeder's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by blaze45 View Post
    I doubt this will fix all your problems on your phone but go into the playstore and download clean master you might have a lot of junk on your phone that needs cleaning....
    sent from my Nexus 7 using tapatalk pro..
  4. #4
    z06mike's Avatar
    Posts
    Global Posts
    2,790 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And also how do you have Kit Kat on your S3. There is no 4.4 update for the S3, which means you have to be rooted.
  5. #5
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by z06mike View Post
    He asked if it was Kit Kat, so I'm assuming he wasn't sure which the latest update was.
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Boot into recovery (Hold volume up, home and power) and clear the system cache.
    If that doesn't work I'd recommend a factory reset. Should be done after any major update anyway
  7. #7
    z06mike's Avatar
    Posts
    Global Posts
    2,790 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by UJ95x View Post
    Ah my bad! I don't know how I missed that.
  1. Verizon S3 volume issues
    By ryanbart in forum Verizon Galaxy S3
    Last Post: 01-24-2014, 01:27 PM
  2. New Moto G user - needs basic help please
    By furkin in forum Moto G (2013)
    Last Post: 01-17-2014, 07:10 PM
  3. Samsung Galaxy S3 no network choices
    By craiggrubbs in forum Samsung Galaxy S3
    Last Post: 01-17-2014, 03:05 PM
  4. S3 keeps reconnecting to wifi router after 4.3 update !!!!
    By baljeet bassi in forum Samsung Galaxy S3 I9300
    Last Post: 01-17-2014, 02:20 PM
  5. 4.3 Update on S3 Randomly Putting Phone in Vibrate Mode
    By JoePaLives in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-17-2014, 11:49 AM
